Wiring the Breaker Panel
OK, so we are wiring up our robot right now, and we ran into a question. Should you wire the breaker panel down in numercial value, or should you load balance them? The reason we ask is the left has only one 30 amp circut , and the right side has the controller, compressor, and 5 spikes topower, about equaling each other out. Any suggestions???
P.S. The rules never mention anything about this, but the guidelines recomend numbering down on every number. Last edited by D.J. Fluck : 04-02-2005 at 12:36. Reason: edit request by team |
Re: Wiring the Breaker Panel
Accodring to the manual for the circuit breaker panel it is said for optimal power you should have the electrical components and their respective breakers be connected from the lowest number possible and then to the next higher number. So you should go from one to two and so on. i don't know how much it affects the power flow if you don't do this but I think it is better to just follow what the manual says.
on the panel, it says to wire from the low numbers to the high ones and put the 30 amp breakers first. it should work fine with these guidelines.
I would think that the reason for going from lowest to highest is for the sensing the tripped breakers. When the panel sees a bunch of un-used slots after a certain one, it knows that they are unused, not tripped.
So if you want the light, and the other data stuff to work right, I would think that you would have to go from lowest to highest like they said. |
I would guess that the guidelines are to minimize the resistance of the paths inside the breaker panel. Keeping that in mind, I would think your proposed arrangment should be just fine.
By following the advice of others and the Breaker Panel Guide you are balancing the loads. A close look at the panel will show that breaker positions 1 and 2 are closest to the input terminal physically and electrically. My recommendation is that the RC be powered from either 1 or 2, minimizing the loss of high current loads on the voltage available to the RC. At this time we are alternating circuit breaker positions to give some distance between circuit breakers for cooling. (i.e. 1,2,5,6, etc.) Use the same convention on the battery returns to keep your wiring straight forward. |
#7
| Digital Breaker Panel | Mark McLeod | Control System | 8 | 31-01-2005 00:22 |
| Breaker Panel weight | Emily Pease | Electrical | 4 | 24-01-2005 12:22 |
| extra connector on breaker panel | sciguy125 | Electrical | 22 | 22-01-2005 12:22 |
| Breaker Panel | Gal Longin | Electrical | 1 | 13-01-2005 16:01 |
| DXF of NEW Breaker Panel? | Chris_Elston | Electrical | 3 | 13-01-2005 15:15 |
