Go to Post Playing fields outdoors in the snow and the only field faults were when you ran out of gas!...ahh the old days - ExTexan [more]
Unread 01-02-2005, 13:38
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Crashing on program download
Yesterday I was downloading code to the RC with my laptop. My program (as in hte one I was modifying) downloaded no problem. Granted, it didn't work and turned on the "Code error" light on the OI, but it downloaded. Eventually, after doing some more work on my program, I got suspicious of the USB to Serial converter and I tried the default code... After a few seconds of output after a successful download, I hit the BSD (blue screen of death. Memory dump junk) and it restarted. Annoyed by the inpudence of the software to quit working, I waited for it to boot up again, logged in, opened IFI loader, and started the download again. And... it crashed. Repeat 3 times.
In summary, I was downloading the default code with a USB to serial converter and a few seconds after a successful download, my Win XP Home laptop crashes. It doesn't, however, do this with my current work, which basically is just with added interrupts. For my program, the OI "code error" light just turns on... Any ideas on what might be causing this? And while you're at it, what exactly are the possible causes of that error light again? Initialization error I know is one, but I checked that...
Unread 01-02-2005, 20:00
Re: Crashing on program download
Before engaging in much speculation about what might be wrong, I suggest you try to eliminate one possible cause: remove and reinstall the IFI loader program. It should not be crashing your computer, and the fact that it is doing so makes your downloaded code suspect.
Unread 01-02-2005, 21:04
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Indeed. It is very difficult to crash a VB program to a BSOD (usually the VB run time catches it first). I wonder is PICBOOT.DLL is at fault...
Unread 01-02-2005, 21:15
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
I wonder if it is the drivers for your USB->serial link.
We had a problem where if we didn't do things in exactly the right order reguarding the serial connection, closing the connection would crash the computer to a BSOD.
The exact name of the program "gift" we are to download? Flynn Programming 2 10-01-2005 21:47
'Program State' LED stays blinking yellow after download clynch Control System 5 18-02-2004 19:34
how to add steps in the provided encoder program for the edu Zaramel2002 Programming 3 11-02-2004 08:35
Fried program slots? Jeff Waegelin Programming 18 19-03-2003 18:08
Ahh! Program trick confusing! archiver 2001 9 24-06-2002 02:26
