Go to Post Sounds fun? Maybe only if you're a giant dork, but I'm a pretty giant dork, so... - Madison [more]
Unread 01-02-2005, 18:11
Steven Carmain Steven Carmain is offline
Bit Twiddler
FRC #2832
Steven Carmain will become famous soon enough
Wiring the Breaker Panel
OK, so we are wiring up our robot right now, and we ran into a question. Should you wire the breaker panel down in numercial value, or should you load balance them? The reason we ask is the left has only one 30 amp circut , and the right side has the controller, compressor, and 5 spikes topower, about equaling each other out. Any suggestions???
P.S. The rules never mention anything about this, but the guidelines recomend numbering down on every number.
2017 - Team 2832 Mentor
2016 - Team 6013 Mentor
2002-05 - Team 45 Software/Electrical
A robot is like a campfire: it takes a while to bulid it, and then everyone surounds it!
A world without standards is chaos. A world with standards is chaos.
Unread 01-02-2005, 18:48
zainali's Avatar
zainali zainali is offline
AKA: Syed Zain Ali
#1241 (Theory 6)
zainali is an unknown quantity at this point
Re: Wiring the Breaker Panel
Accodring to the manual for the circuit breaker panel it is said for optimal power you should have the electrical components and their respective breakers be connected from the lowest number possible and then to the next higher number. So you should go from one to two and so on. i don't know how much it affects the power flow if you don't do this but I think it is better to just follow what the manual says.
Rick Hansen Secondary School
Team 1241
www.Theory6.org
GO LEAFS GO
Unread 01-02-2005, 20:12
Der Sichelmann's Avatar
Der Sichelmann Der Sichelmann is offline
Professional Team Member
#0358 (Eagles)
Team Role: Student
Der Sichelmann is an unknown quantity at this point
on the panel, it says to wire from the low numbers to the high ones and put the 30 amp breakers first. it should work fine with these guidelines.
Unread 01-02-2005, 20:49
ConKbot of Doom ConKbot of Doom is offline
Team Alumni
FRC #1184 (Cobra Robotics)
ConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura about
I would think that the reason for going from lowest to highest is for the sensing the tripped breakers. When the panel sees a bunch of un-used slots after a certain one, it knows that they are unused, not tripped.
So if you want the light, and the other data stuff to work right, I would think that you would have to go from lowest to highest like they said.
Unread 01-02-2005, 20:51
I would guess that the guidelines are to minimize the resistance of the paths inside the breaker panel. Keeping that in mind, I would think your proposed arrangment should be just fine.
Unread 01-02-2005, 22:50
Originally Posted by Steven Carmain
OK, so we are wiring up our robot right now, and we ran into a question. Should you wire the breaker panel down in numercial value, or should you load balance them? The reason we ask is the left has only one 30 amp circut for the Van Door motor, and the right side has the controller, compressor, and 5 valves topower, about equaling each other out. Any suggestions???
Steve,
By following the advice of others and the Breaker Panel Guide you are balancing the loads. A close look at the panel will show that breaker positions 1 and 2 are closest to the input terminal physically and electrically. My recommendation is that the RC be powered from either 1 or 2, minimizing the loss of high current loads on the voltage available to the RC. At this time we are alternating circuit breaker positions to give some distance between circuit breakers for cooling. (i.e. 1,2,5,6, etc.) Use the same convention on the battery returns to keep your wiring straight forward.
Unread 01-02-2005, 22:56
Sscamatt's Avatar
Sscamatt Sscamatt is offline
AKA: Matt Syska
FRC #0195 (Cyber Knights)
Team Role: Electrical
Sscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud of
Send a message via AIM to Sscamatt
Originally Posted by Al Skierkiewicz
Steve,
Wouldn't wiring method go against their recommendation of wiring 30amp circuits first, then 20amp circuits?
2006 Championship Finalist, Thanks 25 + 968!
2006 Newton Division Winner
2006 International Innovation In Control Award
2006 Radio Shack Innovation in Control Award, UTC Regional
RIT Class of 2011
Unread 01-02-2005, 23:15
I consider the RC to be the brains and heart of the robot, so it gets first feed on the electrical. High current loads cause a voltage drop (albeit a small one) across any resistance so by placing the RC first prevents the RC from receiving less than battery voltage. Just my preference.
Unread 03-02-2005, 08:42
DarkJedi613's Avatar
DarkJedi613 DarkJedi613 is offline
Running Riot
AKA: Patrick Cloke
FRC #0358 (Hauppauge Robotic Eagles) FRC #1493 (RPI/Albany High School)
DarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to behold
Send a message via AIM to DarkJedi613 Send a message via MSN to DarkJedi613 Send a message via Yahoo to DarkJedi613
Yeah but we have the backup battery now which makes sure the RC always has the correct voltage, so you shouldn't need to worry about that and should just follow FIRST guidlines, I think.
2003 - 2006 President, Coach, Webmaster Team358.org
2008 Mentor, Team 1493
Team Search | (Updated: 1-16-08)
FIRSTsearch
Unread 03-02-2005, 14:05
I think if you ask around you will find many teams who drained the backup during matches last year and with the backup feeding camera power as well this year... I like making my own luck when I can.
Digital Breaker Panel Mark McLeod Control System 8 31-01-2005 00:22
Breaker Panel weight Emily Pease Electrical 4 24-01-2005 12:22
extra connector on breaker panel sciguy125 Electrical 22 22-01-2005 12:22
Breaker Panel Gal Longin Electrical 1 13-01-2005 16:01
DXF of NEW Breaker Panel? Chris_Elston Electrical 3 13-01-2005 15:15
