Go to Post The MAINTENANCE of teams is just as important as the growth. Starting a new team is not always the answer. - Amanda Morrison [more]
Unread 01-02-2005, 20:34
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
Speed controllers won't communicate w/robot controller
I'm pretty sure I saw someone with the same problem a while back on the forums, but after a good half-hour of searching I couldn't find it - so please excuse me if this has already been solved. I hooked up our robot controller to the speed controllers with the kit-provided data cables, and they blink yellow exactly as if they were not plugged in. I can take the same cable and move it to last year's robot controller, and immediately the light goes solid as it should. Why would the new robot controller not provide the poor Victors with the proper signal? Battery and backup battery, of course, plugged in (although I believe the backup battery is not necessary) and to the best of my knowledge everything is plugged in just fine. I even tried reversing the connectors, with no effect. I certainly hope this isn't a hardware problem...
Shift to the left, shift to the right!
Pop up, push down, byte, byte, byte!
Unread 01-02-2005, 20:44
Re: Speed controllers won't communicate w/robot controller
Probably the most common cause this year has been poorly seated PWM connectors on the victor side. It feels like it's all the way in, but it's probably not. The Victor connection seems to be tighter this year.
Keep wiggling the connector until it only shows about 3/16 of an inch.
Unread 01-02-2005, 22:55
Oh, right. Did I forget to mention that it happens to all 6 of them that we've hooked up simultaneously? I just pushed them all in as far as they could go - there's about .175 inches showing. It seems to be seated quite well.
Unread 01-02-2005, 23:05
sirbleedsalot's Avatar
sirbleedsalot sirbleedsalot is offline
FRC #0939
Team Role: Student
sirbleedsalot has a spectacular aura aboutsirbleedsalot has a spectacular aura aboutsirbleedsalot has a spectacular aura about
Yea I think you were talking about my thread. Um we never really fixed the blinking lights, but the robot runs fine so we are ignoring them. BTW only those on the right side for the drive motors did this.
our web site
Unread 01-02-2005, 23:07
All of mine are doing it - although I haven't hooked up any motors to confirm this, I would assume that they wouldn't work - which puts me in a much more dire position than you apparently were. How did you work around it - non-functioning speed controllers would seem to kill just about any robot (?)
Unread 01-02-2005, 23:26
Steve,
Just on the off chance that the code is corrupt, have you tried to download the default code to the RC and just connect one or two of the default motor controllers? If all of that does not work, there is a chance you have a bad controller. Check with IFI as soon as you can.
Unread 01-02-2005, 23:28
Paul H's Avatar
Paul H Paul H is offline
Renegade of Funk
AKA: Paul Huston
FRC #0033 (Killer Bees)
Paul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant future
Send a message via AIM to Paul H
Did you download the master code update? We did this and it seemed to fix our problem.
-Paul
Unread 01-02-2005, 23:40
Yes, I did. I will, however, do so again tomorrow. But I already did so once.
Unread 02-02-2005, 00:13
You say that plugging the other end into last year's RC made things work, so I doubt it's a connection problem at the Victor. But in case it is, we have discovered that this year's Victors are very finicky about exactly what angle the PWM cable pins are inserted at. Half the Victors weren't responding. I bent the pin on the white end just a teeny bit off center and suddenly all was well.
Unread 02-02-2005, 00:20
I will try that tomorrow, although the pins are already pretty well bent up and it seems rather odd that all 6 would show the same problem if that was in fact it. But it's something to try...
Unread 02-02-2005, 07:58
FRC #0939
Team Role: Student
Well we did not work around it. We hooked up the motors to the victors and the motors ran so I don't think our whole victor is broke just the led. because sometimes when we drive the led just shuts off, but everything still works. That was not much help but try hooking up a motor to the victor, and if that does not work then I would start worrying about the RC like the others said.
our web site
Unread 03-02-2005, 20:56
Justin_302's Avatar
Justin_302 Justin_302 is offline
Justin
AKA: Justin
FRC #0302 (Mechanical Dragons)
Team Role: Driver
Justin_302 is on a distinguished road
Send a message via AIM to Justin_302
You can be getting cross chatter from the data cables. If your input power wires(postitive and ground) are too close to the data cables, it will cause the robot not to work. The power input wires create a magnetic field which messes with the cycle of the victor. Try moving your data cables away from the power input wires.
Team 302
Unread 03-02-2005, 21:26
They aren't very close.
initialization program and speed controllers rosebud Programming 15 05-10-2004 03:35
PID control loops - closed loop feedback KenWittlief Technical Discussion 56 26-04-2004 21:27
not quite sure...speed controller...spike. tophq Programming 8 26-03-2004 13:43
speed controllers & circuit breakers deuceswild Electrical 2 15-01-2003 14:46
Calibrating speed controllers and joysticks thedillybar Technical Discussion 4 11-02-2002 13:24
