Go to Post There is a very fine line between passion and emotion, sometime it gets crossed. Let's not confuse the two. - JohnBoucher [more]
Unread 01-02-2005, 11:12
reilly reilly is offline
reilly is an unknown quantity at this point
stdio.h complilation error
When I compile the 2005 default code I get an error stating- something to the effect -like the linker cannot find the header stdio.h, so I took stdio.h from another machine [with same OS] and placed it in the directory for the project.. and still no luck.
What's puzzling is: [in the preprocessing statments] I don't even see stdio.h declared anywhere.
mmreilly@gmail.com
Unread 01-02-2005, 11:20
Bharat Nain's Avatar
Re: stdio.h complilation error
Do you have the latest compiler installed which was provided by FIRST? You can find it on the FIRST homepage if you don't have it.
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 01-02-2005, 11:49
capenga's Avatar
capenga capenga is offline
Penga boy
AKA: Giovane
#1156 (Under Control)
capenga is an unknown quantity at this point
Send a message via ICQ to capenga Send a message via MSN to capenga
we had the same problem here, and the solution is quite simple:
go to www.microchip.com and get the mc18 2.4 SE... 'cause the mc18 2.2 on the cd have some problems, including the missing of stdio.h
Ignore alien orders.
Unread 01-02-2005, 20:44
Are you speaking about the default code? 2.4 versus 2.2 -because I'm compiling 2.4.
Otherwise, I assume your saying that the MPLAB -cBot CDROM [that came with the kit] is missing some headers and that I should download another version on the link to site you provided. If this is so --can you tell me more specificly what to download [post the exact link] or specify- once I'm at the microchip page exactly which link to go into to begin downloading...
Grazie
Unread 01-02-2005, 20:49
please post your entire set of error messages.
MPLAB build error cabbagekid2 Programming 7 12-01-2005 13:36
error - Invalid 18f8520 header file! vtrehan Programming 2 16-11-2004 08:31
PHP and Wiki Error Venkatesh Website Design/Showcase 2 24-07-2004 15:51
Strange 16 bit MS-DOS subsystem error Crazy_Ed Programming 6 18-03-2004 14:31
strange error Anthony Kesich Programming 2 25-02-2004 18:55
