Go to Post I think it's great the way people involved in FIRST always try so hard not to argue. It's a good sign that all the talk of Gracious Professionalism is working. - BaldwinNYRookie [more]
Unread 01-02-2005, 21:53
Ben.V.293 Ben.V.293 is offline
Ben.V.293 will become famous soon enough
Send a message via AIM to Ben.V.293
Coloring a Robot
This is the first year my team has actually found the time to color some parts and i was wondering what methods teams have used in the past and how well they worked. I'd also like to know how hard some things are and how expensive they can be. I hear paint chips and scatches easily and that powder coating can be heavy. We're pretty much interested in coloring our frame and some of the sub compenents, all of which are alluminum. Would anodizing work well? Any pictures would be great.
Thanks,
Ben Van Selous
Unread 01-02-2005, 21:57
Kyle's Avatar
Kyle Kyle is offline
Mike Wade, RIP You will be missed
AKA: Kyle Rice
FRC #0365 (MOE)
Kyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond repute
Send a message via AIM to Kyle
Re: Coloring a Robot
Spray painting is light weight, easy and most important cheap. it can get messed up a bit but doesn't that just show character?
2007 Championship Chairmans!!!!! 8 years in the making GO MOE!
Facebook
Unread 01-02-2005, 22:06
Ali Ahmed's Avatar
Ali Ahmed Ali Ahmed is offline
FRC #0004 (Team 4 ELEMENT)
Ali Ahmed is a splendid one to beholdAli Ahmed is a splendid one to beholdAli Ahmed is a splendid one to beholdAli Ahmed is a splendid one to beholdAli Ahmed is a splendid one to beholdAli Ahmed is a splendid one to beholdAli Ahmed is a splendid one to behold
We always powder coat our frame and some of the bigger parts of the robots. It will add about 3 pounds to the robot, but thats just an estimation. Also with powder coating, it adds about ten-thousands to the dimension to whatever it is on. So if you have close tolerances then that might be a problem. Anodizing is very nice. It is extremely light-weight and doesn't chip or scratch. But the only problem is that you can only do it to small parts.
Student: Team 22
Mentor: Team 4
Unread 01-02-2005, 22:10
Do u send your parts out for powder coating? I've seen kits in Northern tool. Do you think its something a team could handle on their own? If you do send the parts out to a shop is powdercoating an expensive thing to have done?
Thanks,
Ben Van Selous
Unread 01-02-2005, 22:17
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
Not necessarily - if you have a big enough anodizing tank and a large enough power supply (you need somewhere in the neighbourhood of 4-12 amps per square foot of part surface area) you can anodize anything. We are going to be anodizing most of the aluminum on our robot this year - it's very durable, looks great, is relatively inexpensive, and is fun to do. The only hitch is that most of the stuff we use like extrusion and angle comes already anodized but not dyed, so it takes a bit more work to de-anodize first.
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
Unread 01-02-2005, 22:23
Is this something you do yourselves? If so I'd really like to learn how to do it. Could you post an overview of the process? I really appreciate your help.
Ben Van Selous
Ali Ahmed's Avatar
Yeah we send out for powder coating. We are lucky becuase our school is in a manufacturing district. Actually the second largest in the nation. We also get it done for free. I don't know if you know how powder coating works but you will need the powder and sprayers. You will also need a place to do it and you will need to be able to electricly charge the part you are coating. If you can do that then are set.
Student: Team 22
Mentor: Team 4
Unread 01-02-2005, 22:27
Han Tzu's Avatar
Han Tzu Han Tzu is offline
Team Stander: AKA The Human Playa!
AKA: Metal Master
#0617 (Springers)
Han Tzu can only hope to improve
We have a powder coat with high gloss. Black and gold of courseGetting it painted should probably be done by a professional. If you have problems with runs and drips, you could get it on the robot in places where space can be vital. Of course, the problem with getting it painted is that if you ever have to drill, cut or work it up, your going to be very reluctant to mess up such a nice paint job.
Unread 01-02-2005, 23:13
Circuit Breaker
Sure, no problem.
Please keep in mind that this is a very general overview, since we only started doing this ourselves this year, and haven't quite perfected the process yet.
First off, it may be obvious, but you can only anodize aluminum. Any other kind of metal simply won't work with this method. The part should be really well cleaned before, and keep in mind that the anodized layer is so thin that if you leave a bad finish before anodizing, it will show through afterwards.
The first step is to immerse the part in a basic solution (2 molar NaOH will do the trick) for a short amount of time. This is known as "etching", and the idea behind this, I believe, is that it increases the surface area of the part on an atomic level, making the aluminum more receptive to the oxygen later on. If your part came already anodized, like extrusion, then leaving it in the basic solution for half an hour or so will remove the anodized layer, if you help it along by wiping every few minutes.
The next stage is the actual anodization, in which the part is immersed in a sulfuric acid solution (1.5 molar H2SO4 is what we use). This is done usually by suspending the part with aluminum wire (having any other type of metal in the solution will cause the electricity to flow through it instead of the aluminum). The part gets attached to the positive terminal of a power supply, which is why it's called "anodization". You also need a cathode, which usually is an aluminum plate at the bottom or side of the anodizing tank, hooked up to the negative terminal. We use a 35A manual 12V battery charger as our power supply. The power supply gets turned on, and should be set so that it supplies 4-12 amps per square foot of the surface area of your part. At this current, it usually takes about an hour and a half to anodize a part. What happens during this process is that the water in the solution is electrolyzed, and the hydrogen is released while the oxygen bonds with the aluminum at the anode to form a porous aluminum oxide layer.
The following step is to dye the oxide layer to whatever colour you want. Ordinary fabric dye works fine for this, mixed at twice the normal concentration. This takes 15 minutes to half an hour, and during this stage the dye is absorbed into the pores of the aluminum oxide layer.
The last stage is the sealing, during which the pores are closed, trapping the colour inside. Some people will use special chemicals to seal their parts, but immersing them in boiling water for a few minutes works just fine.
The result of all this is a colourful, slightly matte layer a couple thousandths of an inch thick.
If you're considering trying your hand at anodizing yourself, there are some excellent websites which you should consult, such as this one and this one.
Good luck with your robot colouring!
Patrick Fairbank
patfairbank.com
Unread 01-02-2005, 23:23
russell's Avatar
russell russell is offline
#1430 (WRONG)
Team Role: Electrical
russell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to all
Is that allowed? I thought there was some kind of rule against chemically treating materials for your robot. If this is allowed I will definetly have to try it.
Unread 02-02-2005, 09:17
Golden's Avatar
Golden Golden is offline
#0011 (MORT)
Golden will become famous soon enough
Send a message via AIM to Golden
You cannot paint your robot any color that is on the field. So MOE, what are you guys going to do, since green is the color of the vison tetras?
Our robot is going to black/gray. Personally I would want something like bright orange or pink.
EDIT: I am looking for the exact rule now...
Unread 02-02-2005, 09:47
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
From the Q&A:
Originally Posted by ID 1125
Q: Clarifying Q. 982: This means that teams are allowed to paint their robots the exact same color as the vision tetra, loading zone, or gold triangle to intentionally distract other team's cameras?
A: There is no prohibition against any colors although there is rule <G26> which prohibits a robot from changing its colors to interfere with the vision system. Be aware that opposition robots may well be your partners in some matches.
I read this Q&A as saying that you can paint your robot whatever color you like.
Unread 02-02-2005, 10:34
RogerR's Avatar
RogerR RogerR is offline
its spelled *ya'll*, not *y'all*
AKA: Roger Riquelme
FRC #3844 (Wildbots)
RogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond repute
Send a message via AIM to RogerR Send a message via MSN to RogerR
<R33> states that plating and anodizing are legal.
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
Unread 02-02-2005, 10:57
russell's Avatar
#1430 (WRONG)
Ah, thanks. Sweet, Im gonna try this today on some scraps. Assuming I can get my hands on some chemicals .
Unread 02-02-2005, 15:07
Golden's Avatar
#0011 (MORT)
The camera is set to read the colors of the field, therefore a robot that is colored the same color as a part of the field would be considered distracting...
That how I read it, but where is the rule, cause it doesn't fall under <G26>, thats the entanglement rule.
pic: Team 1073 Presents Scorpius CD47-Bot Robot Showcase 1 07-03-2004 18:30
Building more than one robot / expanding the "season" Mr. Van General Forum 25 19-02-2004 17:51
Controlling a FIRST robot with a Lego RCX Controller? archiver 2001 5 24-06-2002 04:19
Kamikaze Robot Strategy... Joe Johnson Rules/Strategy 30 07-04-2002 21:42
Calling all Lawyers... ...Define "all parts" Joe Johnson General Forum 10 13-03-2002 15:12
