Go to Post People misuse GP because they see Dean as some sort of whimsical cross between the Nutty Professor and Mister Rogers and think that FIRST is Disney World and we're all going to happily hold hands around the campfire and sing happy songs all day long. - Koko Ed [more]
Unread 01-02-2005, 22:50
Re: Wiring the Breaker Panel
Originally Posted by Steven Carmain
OK, so we are wiring up our robot right now, and we ran into a question. Should you wire the breaker panel down in numercial value, or should you load balance them? The reason we ask is the left has only one 30 amp circut for the Van Door motor, and the right side has the controller, compressor, and 5 valves topower, about equaling each other out. Any suggestions???
P.S. The rules never mention anything about this, but the guidelines recomend numbering down on every number.
Steve,
By following the advice of others and the Breaker Panel Guide you are balancing the loads. A close look at the panel will show that breaker positions 1 and 2 are closest to the input terminal physically and electrically. My recommendation is that the RC be powered from either 1 or 2, minimizing the loss of high current loads on the voltage available to the RC. At this time we are alternating circuit breaker positions to give some distance between circuit breakers for cooling. (i.e. 1,2,5,6, etc.) Use the same convention on the battery returns to keep your wiring straight forward.
Digital Breaker Panel Mark McLeod Control System 8 31-01-2005 00:22
Breaker Panel weight Emily Pease Electrical 4 24-01-2005 12:22
extra connector on breaker panel sciguy125 Electrical 22 22-01-2005 12:22
Breaker Panel Gal Longin Electrical 1 13-01-2005 16:01
DXF of NEW Breaker Panel? Chris_Elston Electrical 3 13-01-2005 15:15
