Go to Post The Questions is, do we attempt to build a Mr.Fusion, or do we go for the Plutonium from the Libyans? - dag0620 [more]
Unread 01-02-2005, 22:41
cloudago cloudago is offline
cloudago is an unknown quantity at this point
Send a message via AIM to cloudago
MPLink Error
We ran into a problem when we tried defining unsigned chars in a header file and running into a Linker error that claimed that a variable had multiple definitions.
This is what we have in the header file which causes the error:
long int KP_P = 5;
This is the error given by the Linker:
Error - symbol 'KP_P' has multiple definitions.
This source code does not cause an error:
#define KP_P (5)
Declaring the variable as a long int in the *.c file does not cause any errors, it is only in the header file that it causes the error.
Has anyone run into this error or is it a bug in the Linker?
Unread 01-02-2005, 23:00
probizzle's Avatar
probizzle probizzle is offline
AKA: Prabhas Pokharel
#0639 (Code Red)
probizzle will become famous soon enoughprobizzle will become famous soon enough
Send a message via AIM to probizzle
Re: MPLink Error
It is not a bug in the linker.
When you declare a long int in the header file, every time a .c includes this header file, space will be allocated for KP_P. Even if you have the #ifndef __header_file_name_h_ #define __header_file_name_h_ at the top of the file.
Here is the solution:
declare lont int KP_P in a .c file.
However, also
add
extern long int KP_P;
in the header file.
Now, if you include this header file, you should be able to use KP_P.
Another comment:
the define doesn't show an error, because it is essentially a copy paste operation, and the compiler is smart enough to figure it out.
Code Red Team 639 Winners of the 2005 FingerLakes Regional with 191 and 494.
http://pset.deu83.com << my baby
http://www.setgame.com/set/ << it's mother
Electrical Engineer
Rookie Year: 1995
Re: MPLink Error
This is not a bug. KP_P is defined somewhere else. Either fiond out where or change the variable name.
Mike Betts
As easy as 355/113...
MPLab build error Derek t Programming 7 17-01-2005 09:33
error - Invalid 18f8520 header file! vtrehan Programming 2 16-11-2004 08:31
Confusing Compiler Error UrsaMNet Programming 2 28-10-2004 14:32
PHP and Wiki Error Venkatesh Website Design/Showcase 2 24-07-2004 15:51
Linker Error Max Lobovsky Programming 4 27-05-2004 20:16
