Go to Post "What connection is the most vital to the success of your robot?" The one between the drivers brain and hands, and the one between the coaches brain and mouth. None of the other ones matter if those two don't work. - dlavery [more]
Unread 02-02-2005, 02:34
MikeDubreuil's Avatar
Carpe diem
FRC #0125 (Nu-Trons)
pic: Team 125 Teaser (2005-02-01)
Unread 02-02-2005, 02:37
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: pic: Team 125 Teaser (2005-02-01)
Well, those transmissions and wheels came from AndyMark You will be running on four Chias for the drive. The worm and worm gear are used to actuate the main (lower) joint of your arm, which is powered soley by the Van Door motor. Your robot does not utilize the fisher price motors.
Am I close?
Unread 02-02-2005, 02:48
NoodleKnight's Avatar
NoodleKnight NoodleKnight is offline
24 Hours of LeMons?
FRC #0100 (WHS&CHS Robotics)
NoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud of
Send a message via AIM to NoodleKnight
That worm gear reminds me of the lego worm gears.... regardless, thats one huge gear. Maybe the third gearbox is to couple two FP motors/AM planataries, which drive that enormous worm gear, moving the base of the arm.
WHS/CHS Robotics - Team 100 (2003-2006):
2006- Delphi's Driving Tommorow's Technology @ Davis | Imagery Award @ SVR | 2004- SVR Finalists (w/ 691 and 1280)| 2003- Delphi's Driving Tommorow's Technology @ Sac
Unread 02-02-2005, 09:37
Ryan Foley Ryan Foley is offline
FRC #5687 (The Outliers)
Ryan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond repute
4 transmissions and 4 omni wheels are being used in a 4 wheel holonomic drive, 1 chiphua and AndyMark transmission per wheel. Thats my guess.
Ryan
FRC #5687: The Outliers [2015-?]
FRC #1995: Fatal Error [2007-2009]
FRC #350: Timberlane Robotics [2001-2004]
FRC/FLL volunteer since 2005
Unread 02-02-2005, 10:04
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
That worm gear is insane. What kind of monstrous torques are you expecting?
Team 1257
Unread 02-02-2005, 12:04
petek's Avatar
petek petek is offline
What would Dave do?
AKA: Peter Kieselbach
FRC #3654 (Tech Tigers)
petek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond repute
Send a message via AIM to petek
Makes you kinda wonder if Andy and Mark are finding any time to work or their robot!
Pete Kieselbach
Unread 02-02-2005, 14:09
Rosiebotboss's Avatar
Rosiebotboss Rosiebotboss is offline
2015-16 Divisional LRI - Archimedes
AKA: Dana P. Henry
FRC #0839 (Rosie Robotics)
Rosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond repute
Send a message via AIM to Rosiebotboss
Should I post a pic of your chassis tonight after the welding is complete as part of your teaser?
Co-Founder/Mentor FRC Team 839 / JrFLL Team 137/Rosie Robotics/Agawam HS
Winner NEF District WPI 2016
Regional CA-08 Boston, 12 WPI, Eng'g Excellence, 12-15 UL Safety, 15 Motorola Quality
KPCB Entrepreneurship 04, 05, 06, 07, 10, 11, 13, 14, 15, 16
Rookie All Star and Top Rookie Seed 2002
Paul Harris Fellow, CMP Inspector 05-16, Head LRI NE FIRST JTB 1944-2008 "What did you do with your dash?"
Unread 02-02-2005, 18:59
Kyle Love's Avatar
Kyle Love Kyle Love is offline
Support STEM Education
FRC #3301 (Jay County Robotics)
Kyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond repute
hmmmm.....3 AM shifters and 6" omni's....i'm guessing a 3 wheel drive base with a shifter per wheels..that or a shifting arm (I seriously doubt that) whatever it is I am sure we will be amazed.
-Kyle
Kyle Love
Teams I've been on:
Team 45 - The TechnoKats - Student/Leader/Driver 2004-2007
Team 1646 - Boiler Precision Guessworks - Mentor 2007-2011
Team 3301 - Jay County Robotics - Teacher 2011-Present
Unread 02-02-2005, 19:03
2 Speed Kiwi Bot?
Unread 02-02-2005, 22:09
Ianworld's Avatar
Ianworld Ianworld is offline
AKA Ian Ferguson
AKA: Ian Ferguson
FRC #0694 (StuyPulse)
Ianworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud of
Send a message via AIM to Ianworld
Find that hard to believe. A Kiwi bot will never truly have as much power as a head on 4 wd drive bot. It just doesn't have the power due to weight being distributed on a wheel or wheels that aren't powered in the direction you need. The kiwi bots real advantage is in its maneuverability, which it should focus on. At least thats my take.
Team Website
Unread 03-02-2005, 13:33
Carpe diem
Some of you are very close. Yes, we will be using two AndyMark transmissions for our drivetrain. The third transmission pictured is actually a spare. We might use the AndyMark omni wheels, that's currently under debate. We will have an arm and it will most likely use a worm gear setup (that's currently being designed ).
No, we definitely won't use the worm gear pictured. That was bought accidentally last year and we have kept it around as a joke. Each piece weighs close to 10 pounds and looks like it belongs in a locomotive.
Yeah sure, thank you and your team for helping us. I don't know what we would have done without your help
How do you organize your team? NoodleKnight Team Organization 18 03-11-2005 22:57
pic: Team 830 Rat Pack Teaser Jeff Waegelin Extra Discussion 24 12-02-2005 23:46
pic: Team 858 teaser lt744 Robot Showcase 5 01-02-2005 13:10
pic: Team #93's robot "Tobor 7" Teaser CD47-Bot Robot Showcase 45 23-02-2004 16:03
pic: Team 772 Teaser CD47-Bot Robot Showcase 11 21-02-2004 21:18
