Go to Post The function of that part is to keep one student occupied playing with it during the entire build season. It doesn't have to be the same student all the time, they can take turns. - MrForbes [more]
Unread 02-02-2005, 10:10
BillCloyes's Avatar
BillCloyes BillCloyes is offline
#0677 (The WireStrippers)
BillCloyes has a spectacular aura aboutBillCloyes has a spectacular aura aboutBillCloyes has a spectacular aura about
Re: Cheeseholing suggestions
Originally Posted by Bill Gold
I disagree with your theoretical "professional grade" statement (not that perfection is required on FIRST robots).
I agree completely... A hole saw used on a vertical mill (or even a good drill press with either a 2 axis bed, or really good marking/measuring and center punching) will produce a very good hole. (if you were that worried about it being a 2.000" hole, it wouldn't really be cheese hole...)
As for the wear on the hole saw itself....
* Generally speaking, hole saws are made to be run slowly (bigger diameter the slower spindle speed).
* The use of Cutting Fluid (not just oil (lubricant) or coolant) will quicken the process and also extend the life of the tooling.
-Bill
[ECDU]: Motto Suggestions Bharat Nain FIRST-related Organizations 13 19-07-2004 20:54
Suggestions about champs? Anne Shade Championship Event 25 21-04-2004 16:12
Fantasy FIRST suggestions for next year Joe Ross Fantasy FIRST 39 14-04-2004 01:13
Reputation Level suggestions Brandon Martus CD Forum Support 42 10-01-2004 08:58
