Go to Post However, because they're programmers they just redid the interpolation tables for our motors as opposed to actually fixing the bent shooter. - Nuwanda [more]
Unread 02-02-2005, 13:48
jazzsaxman1988's Avatar
jazzsaxman1988 jazzsaxman1988 is offline
AKA: Hal
#0404 (Distant Rage)
jazzsaxman1988 is an unknown quantity at this point
Send a message via AIM to jazzsaxman1988 Send a message via MSN to jazzsaxman1988 Send a message via Yahoo to jazzsaxman1988
Annoying motor problems...
With the default code, the polarity of the motors needed to be reversed, so I scripted a function that reverses the value of the PWM's. After I did this, I ran it on the bot and I encountered the most curious problem... one set of wheels moves faster than the other. This is my first year with FIRST, and I'm doing about 95% of the coding, so I'm a little lost... I have an idea of how to fix it, but any ideas from the rest of civilization would be appreciated...
Unread 02-02-2005, 13:54
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Re: Annoying motor problems...
First of all, if you just want to reverse the polarity of the motors, you can just switch the output wires on the victor.
The motors spinning at different speeds is likely unrelated to your code. How do you know they are spinning at different speeds? Are your joysticks calibrated correctly? Have you checked both drivetrains for unequal sources of loss?
Team 1257
Unread 02-02-2005, 13:55
JoelP JoelP is offline
whats the P for? Pazhayampallil
FRC #1155 (Bronx Science Sciborgs)
JoelP is a jewel in the roughJoelP is a jewel in the roughJoelP is a jewel in the rough
Send a message via AIM to JoelP
instead of reversing the PWM signals in the code, you could just reverse the polarity on the motors.
[edit] ahh ya beat me [/edit]
Unread 02-02-2005, 14:05
ttedrow's Avatar
ttedrow ttedrow is offline
Herding electrons
AKA: Tim Tedrow
FRC #0281 (EnTech)
ttedrow will become famous soon enoughttedrow will become famous soon enough
Also, you may want to read up on motor controller calibration. Here is the link
http://www.ifirobotics.com/docs/ifi-...nual-dec04.pdf
Sr. Design Engineer
Caterpillar Inc.
Greenville, SC
KD4EGM
FRC 281 Greenvillains
Infected with the FIRST virus in 2000
Yes, Chute Door!!!
Unread 02-02-2005, 14:40
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Ok, so the motors spinning at different speeds is utterly unrelated to programming, and almost definitely has nothing to do with the Victor calibration. The real issue is that all the motors FIRST gives us are wound with a lead angle of some amount. What it boils down to is that they have a preferred direction of rototation. So a given motor will run faster clockwise than counterclockwise. See this for ideas to compensate:
Robot Drifting
Unread 02-02-2005, 14:58
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Before we get too far into this, WHICH MOTOR are you talking about?
Unread 02-02-2005, 16:07
Robot Drifting
Pages 8 and 9 of the FIRST Guidelines, tips, & good practices cover Motor Bias. There it states that there is no inherant bias in the windings of the CIM motor.
There will always be a few % difference between different motors. There can be a few more % in the gearbox and more from the chain tension. Weight distribution can cause the robot to be biased to one side as well. Poor wire connections can cause it as well. You should check all these. Even in the best case, it won't go perfectly straight (although the longer the wheelbase, the straighter). You can play with all of the above things to try and make it better, though.
Unread 03-02-2005, 08:42
AKA: Hal
thanks guys, I got the problem fixed... it was electrical, the speed controllers were different, 1 new and 3 old, and the team didn't calibrate them together... I'm about ready to smack them...
So he was standing there, surrounded by sinners, blasphemers, and the devil himself, and he thought to himself, "Well, no one's perfect..."
Unread 03-02-2005, 08:49
AKA: Hal
VERY annoying problem with AutoCad shoman24v Inventor 4 30-11-2004 11:04
Annoying Private Message Pop-Up Brandon Martus CD Forum Support 6 10-03-2004 22:57
Gyros.. how annoying! randomperson Programming 3 12-02-2003 21:54
Anyone else get those annoying virus warnings? DaveO'B365 Chit-Chat 6 05-04-2002 05:06
Annoying People Are Bad Thread (Post Complaints Here!) Joe Matt Chit-Chat 20 15-02-2002 23:23
