Go to Post I am specifically looking for Rhode Island, Hawaii, New Hampshire, Nevada, California, Florida, ... oh heck, all of the rest. - Rosiebotboss [more]
Unread 01-02-2005, 23:52
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Warning: Motor Failure
For the benefit of all teams, 229 has done extensive testing on the 2005 FP motor. We figured everyone would want to know how well it performs.
Our results are as follows:
Please refer to attached picture.
Motor failed encounter with 20lb dead blow hammer "the answer".
Hopefully teams will use this knowledge to successfully use the FP motor this season. Remember, don't use the FP motor to "block" a deadblow hammer.
Good Luck,
John
PS - This is just a joke. Lots of people have been speculating about how the FP motor will fail under load. I personally have had bad luck with them in the past. Hopefully all teams will be successful using them in 05.
Yes, we really did hit the motor (an old FP) with a 20lb Deadblow Sledge. Yes, it did explode in a cool way. Yes, we're still finding bits of magnet. No, you should NOT try this at home.
Name:	FP Failure.jpg
Unread 01-02-2005, 23:56
russell's Avatar
russell russell is offline
#1430 (WRONG)
Team Role: Electrical
russell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to all
Re: Warning: Motor Failure
Rofl. I couldnt figure out what you were talking about for a second there. We are using the FP motor so I was getting worried that you meant twenty foot pounds of torque, because when I considered the posibility that you actually meant hitting it with a hammer it was just so absurd I dismissed it without even properly registering. The I saw the pic .
Unread 01-02-2005, 23:59
Swampdude's Avatar
Swampdude Swampdude is offline
AKA: Dan Quiggle
FRC #0179 (Children of the Swamp)
Swampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond repute
Well of coarse it'll smoosh if you take the cover off! Duh...
www.179swampthing.org
Unread 02-02-2005, 08:07
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
Well I guess I am starting over on my robot design. The whole design was based around the case strength of the FP!
Andy Brockway
Team 716, The Who'sCTEKS
Unread 02-02-2005, 08:21
petek's Avatar
petek petek is offline
What would Dave do?
AKA: Peter Kieselbach
FRC #3654 (Tech Tigers)
petek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond repute
Send a message via AIM to petek
I think this is a great example of the kind of impact UFHs can have on our community. Any chance of your posting the relative compression strengths of this year's motors? You never can have too much data!
Pete Kieselbach
Unread 02-02-2005, 10:34
John,
You have not indicated the other variables that would be useful in this example. i.e. what was the length of the arm that was holding said hammer? Was it a full swing or just half a swing? What was the weight of the hammer wielder? What was the mcMaster part number for the hammer so others can verify your results? Enquiring minds want to know.
For my own archives did you test the magnetic field before and after the blow and did you measure the wiring resistance following the event? If you only measure the field of all the pieces swept into a pile that is better than nothing.
Unread 02-02-2005, 12:20
Rich Wong Rich Wong is offline
NYC FIRST Planning Committee Member
no team (NYC FIRST)
Rich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond repute
Send a message via AIM to Rich Wong
20lb dead blow hammer.[/size]
Oh Boy, where can I get one of those!
They are also perfect for fine adjustments to the frame, weld-joints, attitudes.
popularis de ob instinctus agnitionis scientia technologia
Home website: www.nycnjfirst.org
Member of NEMO & e^(i*pi)+1 Fraternity.
Member of Friends of Robots
Member of NYCFIRST Planning Committee
Unread 02-02-2005, 12:53
Andy A. Andy A. is offline
Getting old
FRC #0095
Can we expect a White paper on your findings sometime soon?
-Andy A.
Unread 02-02-2005, 14:03
RogerR's Avatar
RogerR RogerR is offline
its spelled *ya'll*, not *y'all*
AKA: Roger Riquelme
FRC #3844 (Wildbots)
RogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond repute
Send a message via AIM to RogerR Send a message via MSN to RogerR
if the 20 lb dead blow hammer is "the answer", then does that make the FP motor "the question"?
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
Unread 02-02-2005, 23:06
coreyjon's Avatar
coreyjon coreyjon is offline
Flight Engineer
FRC #0250 (Team 250 Dynamos)
coreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nice
Send a message via AIM to coreyjon
Hey john, I remember "the answer", I'm working on making something similar..just in case I need to do some percussive maintenance. Had me a little worried with the thread title, but I laughed when I read what you had done to that poor defenseless FP motor. I'll make sure that we don't introduce any of our motors to that kind of torture during the competition.
"Jack of all trades, master of none, though offtimes better than master of one".
Unread 02-02-2005, 23:14
JVN JVN is offline
@JohnVNeun
Originally Posted by coreyjon
...I laughed when I read what you had done to that poor defenseless FP motor.
We debated over and over and over whether we wanted to use the FP motors on the competition robot. As previously discussed... those motors have a tendency to "give up and let out the white smoke" when they are overloaded or used in the wrong application.
As a way of settling the debate, one of our design guys threatened to just flatten 'em. After that, they probably wouldn't have gone on the robot.
We mashed the old one because it was burnt up, and we were boys with a 20 lb sledge.
Basically... it mashed itself. Wrong place, wrong time.
Some background on "the answer":
It was made from scratch by the Clarkson Mini-Baja team. No matter what the question, those Baja guys have got "the answer". It has a reputation all of it's own among the Clarkson SPEED teams. Whenever something "needs some smashing" out comes the answer. Many computers have been "office spaced". All in all it is pretty cool.
It is dangerous though. Ever seen someone get hit by a 20 lb deadblow in the face? (It bounced back up). Not pretty.
So kids... play safe.
John
Unread 03-02-2005, 00:13
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
If you really want the answer, then you certainly need a 42 lb hammer instead...
Shift to the left, shift to the right!
Pop up, push down, byte, byte, byte!
Unread 03-02-2005, 08:32
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
So does this mean we can use the FP as bumpers?
Unread 08-02-2005, 13:54
Dick Linn's Avatar
no team (Synergy)
FP = Fatally Pounded? Flat as a Pancake? Forever Phlattened?
You should play gently with your toys. And pick them up when you are done playing with them.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Misinformation warning Lil' Lavery Rumor Mill 96 03-12-2004 19:28
Printf warning during compile? actorindp Programming 4 20-02-2004 17:02
warning about taxes robot180 Chit-Chat 3 16-10-2003 17:36
Warning, Please Read! Andy Grady General Forum 17 09-03-2003 20:50
WARNING...NO CALLS IN THE ELIM. ROUNDS!!!! archiver 2000 5 23-06-2002 22:35
