Go to Post what is it exactly that makes people like Dave Lavery more admirable than the video store clerk down the street? - Madison [more]
Unread 01-02-2005, 19:06
Billfred's Avatar
Billfred Billfred is offline
Showing PSI in user mode?
Alright, I've seen certain people say that they've been able to get air pressure to appear as the user byte on the OI.
The problem is, I'm not sure how to read such data from the RC, and searching CD doesn't seem to turn up any information.
Can anyone shed some light on this?
Thanks!
Unread 01-02-2005, 19:22
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
Re: Showing PSI in user mode?
Thanks!
User_Byte1 = yourvariablehere;
Then you can push the 'select' button on the operator interface to toggle between the different userbytes (you can define up to six). I believe that userbytes 1 and 2 are the only ones that show up on the OI, but I haven't been able to check this. Actually, I haven't even been able to check that the code above works. I'm only about 80% sure it does. All of the userbytes can be read through the Dashboard port by a Dashboard program.
Hope that helps.
Unread 01-02-2005, 19:29
Billfred's Avatar
Well, that's half of the battle.
Now, at the risk of posting this in the wrong forum, how do I read the information from the pneumatic system to the RC?
Unread 01-02-2005, 20:10
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
There was an analog pressure sensor provided last year, not sure if it's in the kit this year, but I would guess that it would be legal anyways - probably off the shelf. It's just like any other analog sensor.
Shift to the left, shift to the right!
Pop up, push down, byte, byte, byte!
Unread 01-02-2005, 20:46
Following the parts use flowchart, the analog sensor provided in the past may not be used this year. This is because it is a pneumatic component, which takes precedence over being a COTS electronic item.
Edit: see my post below
Unread 01-02-2005, 22:59
I'm sorry. I spoke without justification
That really is too bad, though - the analog sensor was quite a cool addition to the kit.
Unread 01-02-2005, 23:02
Few teams used the pressure transducer, and opted for the digital pressure switch. I believe FIRST opted for the accelerometer from TI over the pressure sensor because it wasnt a widely used item, and this years game moves alot of weight very high. This causes tipped bots, and the accelerometer may be able to help that.
Unread 01-02-2005, 23:04
You say that as if they were mutually exclusive items - both would be really cool. Personally, I would prefer the pressure sensor - I've had just about an infinite amount of trouble with integrating accelerometers in the past
They're too finicky for my taste - I prefer the sensors that just work.
Unread 02-02-2005, 15:16
Actually, a pressure transducer is allowed in <R91>. It seems there is a box missing from the part use flowchart. You can use any pressure transducer as long as it is rated for the pressures you apply and you account for the costs.
Unread 02-02-2005, 15:24
ntroup's Avatar
ntroup ntroup is offline
WildStang!
None #0111 (Wildstang)
ntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud of
I am not so sure about that. According to Q&A ID:1350:
Q: R88 indicates that the Nason pressure sw. is required if we use the pump, but it's not mentioned as a 'minimum' in R86. May we use the analog sensor instead? May we run the pump all the time and not install either sensor?
A: Part 1: You must use the pressure switch. You cannot use the analog sensor. Part 2: You may run the pump all the time; you can ignore the sensor BUT you MUST use the sensor. It is unwise to run your pump all the time as it uses power from your battery.
That seems to say very clearly that the analog sensor (pressure transducer) can not be used..... for whatever reason, I am not sure. Unless I am interpreting this wrong?
-Nate
Unread 02-02-2005, 15:45
-Nate
There are two possible interpretations. The first one is that the analog sensor may not be used under any circumstances. The second is the analog sensor must not be used in place of the pressure switch, but it may be used to supplement the pressure switch.
Unread 02-02-2005, 16:11
ntroup's Avatar
WildStang!
I agree... I have read it both ways, but am not sure their intent on the ruling. If you read it point-blank, it looks like it is -not- allowed. But, I can't seem to figure out their reasoning behing banning it outright (as long as a pressure switch is also used), so I tend to think they are just meaning it can not be used are a direct replacement.
I continue to scratch my head at this, and some other of their answers...
Unread 02-02-2005, 16:52
Mike Soukup's Avatar
Mike Soukup Mike Soukup is offline
Software guy
FRC #0111 (Wildstang)
Mike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond repute
If it's legal, here's how we did it last year before we were forced to use the digital sensor instead of the analog:
#define PUMP_120_PSI_VAL  223
User_Mode_byte = ((Get_Analog_Value(rc_ana_in01) >> 2) * (int)120) / (int)PUMP_120_PSI_VAL;
Mulit-postioning with pnuematics this year? KenWittlief Pneumatics 101 01-02-2005 21:54
Reputation Level suggestions Brandon Martus CD Forum Support 42 10-01-2004 08:58
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
User mode toggling JLambert Programming 2 25-02-2003 05:47
Select button and user mode n[ate]vw Programming 2 20-01-2003 16:33
