Go to Post Don't you hate it when you can't find the droids you're looking for? - Jared Russell [more]
Unread 02-02-2005, 18:17
Drok00 Drok00 is offline
Guy With Fluffy Hair
AKA: Jason Petrilla
FRC #0698 (Grizzly Bots)
Drok00 is on a distinguished road
Send a message via AIM to Drok00
Default Code Difficulties
For some reason the default code (V2.2) has the controller mapped funky, inorder to move the robot forward, you have to move the joystick to the right, reverse o the left etc...basically its all rotated 90 degreesoff what it should be... does anybody have a solution to this problem ( note, my and my accomplice are not programmers, if you could also provide a sample of the "corrected" code we would be very grateful.)
Unread 02-02-2005, 18:47
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
Re: Default Code Difficulties
I know this is REALLY, REALLY stupid, and sorry in advance for insulting your intellegence, but are you sure you have the joystick in the correct orientation, physically? Seconec, make sure you are using PWM output 1 for the left side, 2 for the right.
Aren't signatures a bit outdated?
Unread 02-02-2005, 19:18
AKA: Jason Petrilla
the joystick is definatley in the correct orientation ( we already eliminated that possible problem by using last year's control setup) and in the default code it uses port 13 and 15 not 1 and 2 furthermore the joystick in port one uses pwm outs 1,5,9, 13&14 (same signal) , and 15&16(same signal)
Unread 02-02-2005, 20:56
AKA: Jason Petrilla
okay we figgured it out. ... all we had to do was re wire the motors... i feel like an idiot now... thanks for the help
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
Victors, Default code, & joystick configuration Vermatitis Control System 4 27-01-2005 16:01
user code to default code phoenixomega001 Programming 5 09-01-2005 00:09
Is default code already loaded? quickie25 Electrical 8 19-02-2004 22:51
