Go to Post Wow! Can I be wrong too? Please! - dlavery [more]
Unread 02-02-2005, 19:15
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Re: 2-sided faces?
I thought there is a shell modifier (or equivalent) in 3dsmax. There is a face extrude modifier, though i'm not sure if that would work with the cone. Why not just remake the cone wiht thickness?
If that's no good, there is a flag in the render option box that says "force 2-sided" I believe that should work.
Team 1257
How to cut flat sided holes for Globe and Door motor Max Lobovsky Motors 8 13-01-2005 14:09
inventor to 3D faces format Ken Ginger Inventor 0 27-12-2004 20:19
two sided timing belt archiver 2001 3 23-06-2002 22:34
Dual Sided Timing Belts Lachuck894 Technical Discussion 9 14-01-2002 10:10
