Go to Post Enjoy doing what you do. If you enjoy your life, what you're doing in it, and how you're living it, then what other people say or think doesn't matter. - Beth Sweet [more]
Unread 02-02-2005, 19:40
Umm Errr...
WEIRD compiler error
I have a project that compiles just fine with older C18 versions, but
when i try to compile it under 2.4 i get the following errors:
C:\mcc18\h\p18f8520.h:169:Error [1109] type mismatch in redeclaration of 'PORTBbits'
C:\mcc18\h\p18f8520.h:201:Error [1109] type mismatch in redeclaration of 'PORTCbits'
My project does not even reference these files anywhere in code. It uses ifi_picdefs.h. Does anybody have any idea whatsoever how to fix this?
1139 Alumni
Unread 02-02-2005, 19:43
IMDWalrus's Avatar
IMDWalrus IMDWalrus is offline
This is a line...
AKA: Paul
FRC #0818 (Genesis '02)
IMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to behold
Send a message via AIM to IMDWalrus
Re: WEIRD compiler error
Which version of the default code are you using?
If you're not using version 2.4 (the one with the camera code), that could be your problem.
Unread 02-02-2005, 19:47
I think the problem might be that you have two files of different vintage.
p18f8520.h has to match ifi_picdefs.h, and p18f8520.h has probably changed from the earlier versions of C18.
See if there's a difference between the current default code's version of ifi_picdefs.h and the older one you're using.
P.S. p18f8520.h gets dragged in by the compiler based on the target PIC model called out by the "-p=18F8520" statement in the compile line.
Unread 02-02-2005, 19:56
Umm Errr...
P.S. p18f8520.h gets dragged in by the compiler based on the target PIC model.
It looks like you are right That particular union is different in both files. If the compiler automatically drags in p18f8520.h do you have any idea what the purpose of ifi_picdefs.h is?
1139 Alumni
Unread 02-02-2005, 20:32
Looking more closely I'm not so sure that really is the answer.
I tried removing my p18f8520.h file, then compiling and my project didn't mind a bit that it was gone.
Maybe for some reason the old project is dragging that file in, but shouldn't be.
Unread 02-02-2005, 21:37
Umm Errr...
No you were right. I replaced ifi_picdefs.h with a copy of p18f8520.h, added the following code and now it works. I'm not really sure what that code snippet does, but it is includeed in ifi_picdefs and ifi_default checks to see if UNCHANGEABLE_DEFINITION_AREA is defined. If it is not, it throws an error. Everything works fine now. I am going to update the compiler on all my computers, and replace ifi_picdefs.h with the ifi_picdefs.h from the 2005 default code.
#if defined(BANKED)
#error *** Error - Invalid 18f8520 header file!
#else
#define UNCHANGEABLE_DEFINITION_AREA 1
#endif
1139 Alumni
Unread 02-02-2005, 21:41
Good deal!
Glad it worked out. As you know, it can be really hard to recreate someone else's error sometimes, so sometimes it's just semi-educated guesswork.
Unread 05-02-2005, 14:09
pakrat pakrat is offline
Rich Ross
no team (The Rat Pack)
pakrat is just really nicepakrat is just really nicepakrat is just really nicepakrat is just really nicepakrat is just really nice
Send a message via AIM to pakrat
WE just got the exact same problem, how you do you fix it again??
MPLink Error cloudago Programming 2 01-02-2005 23:00
IMPORTANT regarding the new C Compiler dlavery General Forum 12 14-01-2005 05:05
MPLAB IDE 6.60 Error mchan1111 Programming 8 08-11-2004 20:17
Confusing Compiler Error UrsaMNet Programming 2 28-10-2004 14:32
PHP and Wiki Error Venkatesh Website Design/Showcase 2 24-07-2004 15:51
