Default Code Difficulties
For some reason the default code (V2.2) has the controller mapped funky, inorder to move the robot forward, you have to move the joystick to the right, reverse o the left etc...basically its all rotated 90 degreesoff what it should be... does anybody have a solution to this problem ( note, my and my accomplice are not programmers, if you could also provide a sample of the "corrected" code we would be very grateful.)
Re: Default Code Difficulties
okay we figgured it out. ... all we had to do was re wire the motors... i feel like an idiot now... thanks for the help
| Team THRUST - Kevin's Code and Camera Code Combine | Chris_Elston | Programming | 3 | 31-01-2005 22:28 |
| Victors, Default code, & joystick configuration | Vermatitis | Control System | 4 | 27-01-2005 16:01 |
| user code to default code | phoenixomega001 | Programming | 5 | 09-01-2005 00:09 |
| heres the code. y this not working | omega | Programming | 16 | 31-03-2004 15:18 |
| Is default code already loaded? | quickie25 | Electrical | 8 | 19-02-2004 22:51 |
