Go to Post I don't play with robots, it's much more serious than that. - Al Skierkiewicz [more]
Unread 02-02-2005, 22:12
K.Shaw's Avatar
K.Shaw K.Shaw is offline
The Zoomin' Human
AKA: Shaw 1, kevshaw, little shaw
FRC #0237 (Sie-H²O-Bots (See-Ho-Bots), FLL #3954 (Swift Eagles))
K.Shaw has a brilliant futureK.Shaw has a brilliant futureK.Shaw has a brilliant futureK.Shaw has a brilliant futureK.Shaw has a brilliant futureK.Shaw has a brilliant futureK.Shaw has a brilliant futureK.Shaw has a brilliant futureK.Shaw has a brilliant futureK.Shaw has a brilliant futureK.Shaw has a brilliant future
Send a message via ICQ to K.Shaw Send a message via AIM to K.Shaw Send a message via MSN to K.Shaw Send a message via Yahoo to K.Shaw
Question Van Door Motor Problem
OK so heres what happened....we designed and built our arm going by the specs FIRST gave us on the Taigene Van door motor and it was supposed to run at a free speed of 75 RPMs but once we hooked the arm up and tested it for the first time it was going really slow. so we made a mark on the motor shaft and timed it and it only was running at 50 RPMs under no load....has anyone else had this problem? or if anyone has a comment on this? we are kind of stumped
p.s. we tested one of the previous years van door motors and it ran at almost 80 RPMs.
2005 Bash @ the Beach Winners -Thanks Team 1511 and Team 181
2005 NJ Regional Finalist -Thanks again to 56 and 303
2005 Radioshack Innovative Control Award-NJ
2005 FLR Semi-Finalists
2005 Radioshack Innovative Control Award-FLR
2004 Archimedes Divisional Semifinalists
2004 NJ Regional Winners. -Thanks Team 56 and Team 303!
2004 NJ G.M. Industrial Design Award Winner
2004 UTC Motorola Quality Award Winner
Unread 02-02-2005, 22:16
occra 23.
AKA: ryo
None #1481
Re: Van Door Motor Problem
how confident are you about your electrical connections? resistance will affect a bit. and how full were your batteries?
Unread 02-02-2005, 22:19
K.Shaw's Avatar
The Zoomin' Human
the batteries were fully charged...12.7 under load...and it was connected right to the battery soo there wasn't any resistance
Unread 02-02-2005, 22:20
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
If you have it hooked up into a drivetrain of some sort, there is no way it should be running at free speed even if there is no load on the arm, slider, winch, whatever. Chains, gears, shafts create friction that will slow it down when you think its under "no load"
Team 1257
Unread 02-02-2005, 22:24
K.Shaw's Avatar
The Zoomin' Human
no the tranny on the arm doesnt cause enough friction to slow it down at all...#1 your talking a 33% decrease in speed from 3 gears and chain....and #2 we tested it alone w/o anything also and it ran the same speed of 50 RPMs
Unread 02-02-2005, 22:28
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Can someone just duplicate this test on a new Taigene and post your results here?
OR
Is there a known fault in the no load speed on the Taigene spec sheet??
Unread 02-02-2005, 22:35
K,
Since it is a new motor, the lubricant hasn't really had a chance to distribute itself inside the case. Run it for a while and I think you will find it will speed up. Due to the odd shape of this motor, they are often dropped or set down hard on the shaft (threaded end) which causes a bent shaft or a crack on the back side of the gearbox, this could cause misalignment of the gears and results in slow free speed. If you find a small crack, there is no coming back from this failure and it will only get worse with time.
Unread 02-02-2005, 23:53
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
188 tested the van door's free speed, and also got around 50 rpm. We didn't run it long enough for any significant wear on the worm gear or lubricant redistribution to take place. Older van door motors did indeed perform differently, but like Al said, it might be due to being a brand new motor, not yet broken in.
Maybe someone could lightly load a motor (known to run at 50 rpm) for a half-hour, and then re-measure the free speed, to see if any change took place.
Unread 03-02-2005, 00:02
K.Shaw's Avatar
The Zoomin' Human
its worth a try i guess
Unread 03-02-2005, 20:56
K.Shaw's Avatar
The Zoomin' Human
ya we ran the motor for over 30 min and it didnt really do much for speed....if anyone else has had the slow motor problem please post....
Unread 04-02-2005, 08:31
Our 2005 Van Door motor also runs ~50rpm free speed.
[edit]
I looked up the history of the Taigene spec.
See this thread http://www.chiefdelphi.com/forums/sh...hlight=taigene
In particular Joe Johnson's posts on the revised Taigene specs.
Unread 04-02-2005, 09:44
David Guzman's Avatar
David Guzman David Guzman is offline
AKA: Dave
FRC #1251 (The Techtigers)
David Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant future
Ok, lets say that the speed of the motors doesn't get better, what would this mean? Are the specs wrong? or is there a problem with the motor? would they be less reliable?
Unread 04-02-2005, 10:42
Specs would be wrong. The results have been duplicated (or I suppose, the whole batch donated to FIRST could be defective, but that seems unlikely).
Unread 05-02-2005, 00:10
Veselin Kolev's Avatar
Veselin Kolev Veselin Kolev is offline
X51 Production Company PGM (TM)
Veselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond repute
okie... some work was required in finding this out (not really) but its ok. its all for you guys.
The old motors are 75 rpm. The new ones look the same. And have a free rpm of 50. Life sucks. But.. the good part is that they have the same power. Torque is greater in the new motor, they equal out to roughly the same power. So... all it does is force all you people using it to redesign. Great...
Unread 05-02-2005, 00:54
K.Shaw's Avatar
The Zoomin' Human
so they didnt edit the spec then is what your saying? thats great...
Van Door Motor Thermal Overload Protection bigqueue Motors 1 23-02-2004 07:16
Van Door Motor Drawings Jonathanb Motors 9 03-02-2004 18:32
Attn Wildstang: Found your van Wetzel Chit-Chat 4 21-04-2003 21:41
We can't compete, need van door motor archiver 2000 1 23-06-2002 22:59
van door question archiver 2000 1 23-06-2002 22:27
