Go to Post My first reaction was "Where am I am gonna find pool noodles AND inner tubes in the middle of winter in Michigan?" - KTorak [more]
Unread 02-02-2005, 18:38
DinkyDogg DinkyDogg is offline
DinkyDogg is an unknown quantity at this point
Combining multiple objects in different files into the same scene and file?
I built a field and a robot in two seperate files in 3DS, and now I can't figure out how to combine them. I assume it must be possible. Does anyone have ideas? The only way I can think of is to export one model as a mesh, and then import it again and that's far from optimal.
Any more experienced users have some advice? Thanks!
-jake
Unread 03-02-2005, 00:03
rowe rowe is offline
Eric Rowe
FRC #1097 (Site 3 Engineering)
rowe has a spectacular aura aboutrowe has a spectacular aura about
Send a message via AIM to rowe Send a message via MSN to rowe Send a message via Yahoo to rowe
Re: Comining multiple objects in different files into the same scene and file?
-jake
I am using your situation on purpose. I like to model each different (major) object separately, then combine it in a scene when I'm ready to do the animation. Heres how I do it: In File, there should be an option to Xref. From that dialog, select the file you want to Xref, and then the objects. They should appear in the middle of your scene. (You'll have to keep the original file, but you can make minor changes in the original an then update them in the whole). Another way would to import a .max file into the scene (I haven't tried, so i don't know if it works, but it should keep the exact work you had if u do it that way as well). Hope that helps.
Eric Rowe | Alumn
Team 1097 | Site 3 Engineering
2005 Silicon Valley Regional Finalists
2005 Silicon Valley Regional Sportsmanship Award
2005 Sacramento Regional Finalists
2005 Sacramento Regional Sportsmanship Award
2004 Silicon Valley Regional Sportsmanship Award
2004 Sacramento Regional Visualization Award
2004 Sacramento Regional Engineering Inspiration Award
Unread 03-02-2005, 08:56
Yov's Avatar
Yov Yov is offline
Masterofsquirrelz
#1657
Yov is a jewel in the roughYov is a jewel in the roughYov is a jewel in the roughYov is a jewel in the rough
Send a message via ICQ to Yov Send a message via AIM to Yov Send a message via MSN to Yov
Re: Combining multiple objects in different files into the same scene and file?
file>merge
<Patrician|Away> what does your robot do, sam
<bovril> it collects data about the surrounding environment, then discards it and drives into walls
2005 Israel regional Winner
2005 Radioshack Innovation in Control Winner
Unread 03-02-2005, 17:31
I tried using Merge, but they didn't appear in my scene. Xref sounds like a very cool idea. I'll give that a try. Thanks!
Unread 03-02-2005, 18:22
My model is divided into a bunch of groups, and I'm gonna give it to my friend to add constraints. When I use Xref Scene to import it, it's all one solid block, and I can't move it without binding it to something. Is tehre any way to preserve the groups? That would be really useful.
Unread 04-02-2005, 10:47
Kevin Thorp's Avatar
Kevin Thorp Kevin Thorp is offline
AKA: Kevin Thorp
FRC #3489 (Category 5)
Kevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond repute
Merge should work. It gives you a list of objects in the scene you're trying to bring in. Select the ones you want. If you don't select anything then nothing will merge.
Unread 04-02-2005, 14:51
Yov's Avatar
Yov Yov is offline
Masterofsquirrelz
#1657
Your merged model is probably too small or too big, hit the H key and see if it exists, if not contact me and i'll try to help you out.
Unread 04-02-2005, 21:04
syntaxers's Avatar
syntaxers syntaxers is offline
3dsmax Master
AKA: Chi Feng
#0830 (Rat Pack)
Team Role: Webmaster
syntaxers is an unknown quantity at this point
Send a message via AIM to syntaxers Send a message via MSN to syntaxers Send a message via Yahoo to syntaxers
You should also check to make sure they are using the same units, and as Yov said, you should check to see if it is really big or small.
- Chi Feng - Team 830 Forums
Unread 19-02-2005, 19:14
UsmanB UsmanB is offline
Michigan Wolverine CO/2009
None #0123 (123 Cosmos)
UsmanB will become famous soon enough
i have the same problem, and the thing with mine is that i've added effects thru video post and once i cross refrence i lose the video post :S can anyone tell me how to do that with the video post editing?
