Go to Post Screws come even smaller, #0000 - 160 at Small Parts.They're about $4 each, and made by elves. - DonRotolo [more]
Unread 29-01-2005, 18:36
Yan Wang's Avatar
Yan Wang Yan Wang is offline
Ithaca is Gorges
AKA: John Wayne
FRC #0639 (Code Red Robotics)
Yan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud of
Send a message via ICQ to Yan Wang Send a message via AIM to Yan Wang Send a message via MSN to Yan Wang Send a message via Yahoo to Yan Wang
Re: Using Extruded Aluminum to telescope.
I posted a picture on CD of our 2004 robot's sliding nylon piece of our scissor lift. We manufactured it.
http://www.chiefdelphi.com/forums/pi...&quiet=Verbose
Code Red Robotics Team 639 Alumnus | www.team639.org
<Patrician|Away> what does your robot do, sam
<bovril> it collects data about the surrounding environment, then discards it and drives into walls
Unread 29-01-2005, 22:49
WizardOfAz's Avatar
WizardOfAz WizardOfAz is offline
Lead Mentor
AKA: Bill Bennett
FRC #1011 (CRUSH)
WizardOfAz will become famous soon enough
Send a message via AIM to WizardOfAz
Originally Posted by Dzdconfusd
We have done many arms using either nested Al tubing or monocoque. We make slide bearings out of HDPE tosit between the inner and outer arm. We also use window tape to run the arm in and out. Just a coup[le ideas to ponder...
Can you elaborate a bit on "window tape"?
Do you use it as a spring to extend the arm, then pull it back some other way? Or do you push with it? Or what? Can you say where you get it, what product?
Thanks
Unread 03-02-2005, 11:16
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
Three years ago my team Had to manufacture our own sliders out of nylon, it was tedious work, but they held up well. You want to also watch out for how you have your mast arranged, because if you use a lot of cable and oulleys the upkeep on it is horrid .
Unread 03-02-2005, 12:00
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Thanks
Window tape used to come in the KOP (until 2001?). It is a black nylon ribbon about 1/8" thick that has rectangular cutouts in it that keep it tracking on pulleys. I believe it is available through Small Parts. (Don't remember because we have so much of it we haven't bought it in a while.)
We have a design that allows us to use the "track" on the tape to both extend and retract the arm with a motor driving it. We drive the arm up the tape more or less. Below are the best 2 picture I could find on our website. We have used this mechanism in 98, 99, 01, and 03. I'll see about getting some better pictures of it at tonight's meeting.
http://www.swindsor.k12.ct.us/Highsc...t_Pit_engpoint
http://www.swindsor.k12.ct.us/Highsc..._Pit_fromabove
Edit: Forgot the URL of our homepage. http://www.swindsor.k12.ct.us/Highsc...s/clubs/first/
Unread 03-02-2005, 12:32
petek's Avatar
petek petek is offline
What would Dave do?
AKA: Peter Kieselbach
FRC #3654 (Tech Tigers)
petek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond repute
Send a message via AIM to petek
Cybersonics has been making telescoping structures out of extrusions for years, mostly 8020 1010, though we used Bosch 2020 last year. Instead of using linear bearings, they just interlock parallel extrusions and apply a little lithium grease.
The engineer in me cringes every time I look at how we do it, but it's simple, it works and is very light weight. I think the key to this working is the hard anodized coating on the aluminum keeps it from galling. Needless to say, I wouldn't expect this to work for a real long time, but the only problem we've had (besides cringing engineers) is when the strut gets bent, but that would be a problem with linear guide bearings, too.
Pete Kieselbach
Unread 04-02-2005, 15:48
Here are the pictures I promised. They are of the base and end of two different telescoping arms we have made. Our 1999 bot which has an Al monocoque design. And our 2003 robot which use extruded Al box. If you look carefully at the pictures labeled shoulder and wrist end you should be able to discover how this works.
Pete
Name:	arm extender 99 wide angle.JPG
ID:	2899  Click image for larger version
Name:	arm extender 99.JPG
ID:	2900  Click image for larger version
Name:	Arm extender shoulder.JPG
ID:	2901  Click image for larger version
Name:	arm extender wrist end.JPG
Unread 07-02-2005, 12:43
WizardOfAz's Avatar
Lead Mentor
AKA: Bill Bennett
FRC #1011 (CRUSH)
Thanks for posting the pix, makes the use of the window tape clear.
Torsional Stiffness of Extruded Aluminum Ben Piecuch Technical Discussion 3 19-01-2005 21:55
where can I get info on extruded aluminum? SCYTE16 General Forum 21 13-01-2005 14:23
Mini extruded aluminum Ravi U Technical Discussion 7 17-01-2004 02:12
