Go to Post I haven't invented anything for an hour or two. I need to get back to work. - MrForbes [more]
Unread 03-02-2005, 11:23
Squall Squall is offline
Squall is an unknown quantity at this point
Some things i'm trying to understand on Kevin's Accelerometer Code
We're trying to get our accelerometer to work here with Kevin's Code, that part is easy, but we're trying to understand everything on the code so that we can make the modifications we need.
We're having a special interest on this part :
adc_result = ADRESH;
adc_result << = 8;
adc_result += ADRESL;
We've understood that it's reading the High bits of the ADC and then it'll copy it do the lower part of the adc_result variable, this part I really can't understand. Why does he do this ?? I've been trying to figure out for a while now, does anyone have a clue ?
Thanks
Girafales - TEAM #1382
Unread 03-02-2005, 11:47
Matt Leese Matt Leese is offline
Been-In-FIRST-Too-Long
FRC #1438 (The Aztechs)
Matt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond repute
Send a message via AIM to Matt Leese
Re: Some things i'm trying to understand on Kevin's Accelerometer Code
The ADC input comes in the form of a high byte and a low byte. In order to copy that over to an integer, you have to copy them separately. The first part has the ADC high byte copied over and then left shifted by 8 bits. This means that the value of the ADC high byte is in the high byte portion of the adc_result variable. Then, the ADC low byte is added in so that both values are there.
Matt
Unread 03-02-2005, 12:01
Originally Posted by Squall
	adc_result <<= 8;
The <<= "left shift" operator moves the value toward the upper part of the variable. With that correction, you should understand the code fine now.
Kevin Watson's Kick-off Demo Code! Mr. Lim Programming 27 22-01-2005 03:38
Updated Encoder Code Available Kevin Watson Programming 2 04-01-2005 01:00
A Centralized Code Dump? colt527 Programming 29 01-01-2005 16:07
Recovering code from the RC Orborde Programming 15 04-12-2004 20:02
Coding / Style Standards for sharing C code Joe Johnson Programming 33 01-05-2004 15:15
