Go to Post Trust your data! - eugenebrooks [more]
Unread 03-02-2005, 13:18
Varun Varun is offline
Team Captain
FRC #1219 (Iron Eagles)
Varun is an unknown quantity at this point
Pneumatics ordering
Hey,
Can anyone post whether the magnet cylinders ( M ) has the magnetic switch as an addition to the cylinder or is it attached to the cylinder.
Unread 04-02-2005, 13:54
BillCloyes's Avatar
BillCloyes BillCloyes is offline
#0677 (The WireStrippers)
BillCloyes has a spectacular aura aboutBillCloyes has a spectacular aura aboutBillCloyes has a spectacular aura about
Re: Pneumatics ordering
Originally Posted by Varun
Hey,
The "switch" or sensor is a separate piece that fits onto the cylinders with something similar to hose clamp (its been a while since I've looked at them)
They do not have to be used with a magnetic cylinder (they can be taken off the cylinder).
Just keep in mind, the sensors will not work on regular cylinders; only those with a "M" preceding the part number (stamped on sidewall of cylinder) have the magnetic pistons used to trip the switches/sensors.
If you order magnetic ones from Bimba (as the free ones) you get the sensors included. I am not sure if they are separate items (thus, an additional cost) if procured elsewhere.
-Bill
Using previous years pneumatics? ChuckDickerson Pneumatics 0 30-01-2005 18:22
General Pneumatics Drok00 Pneumatics 8 11-01-2005 23:35
pneumatics and joysticks Jared Stofflett Pneumatics 3 24-02-2004 23:56
pneumatics and joysticks Jared Stofflett Programming 1 24-02-2004 17:45
where to purchas pneumatics Greg Needel Pneumatics 1 14-02-2004 19:24
