Go to Post a robot that is broken shows that it has survived more than a robot that doesn't even have a scratch. - robot180 [more]
Unread 03-02-2005, 13:33
Re: trentonDrive.c: our joystick/wheel drive code
Originally Posted by Anton
Each time I compile the function it says
C:\FrcCode2005v2.2\trentonDrive.c:164:Error [1105] symbol 'pwm10' has not been defined
C:\FrcCode2005v2.2\trentonDrive.c:164:Error [1101] lvalue required
do you know what could be the problem?
Probably missing a required compiler flag in MPLAB for the FRC. The code isn't setup for the EDU controller.
Project -> Build Options... -> Project
MPLAB C18 tab
By "Macro Definitions" click on "Add..."
type _FRC_BOARD in the popup, then OK
Build everything again.
Unread 03-02-2005, 14:40
Anton's Avatar
Anton Anton is offline
Anton Povzner
#1581 (Element)
Anton can only hope to improve
MPLAB C18 tab
I already fixed the problem by including everyhing included in user_routines.c to your file. It probably is just a waste of resources, but I think that i'll find by trial&error the neccesary files to be included.
thanks anyway.
What is wrong with this code???? It won't Compile and I don't know why? Please Help CrashZero Programming 23 26-03-2004 09:44
Changing 1 joystick code to 2 (rookie team) Brawler006 Programming 5 20-02-2004 17:00
TechnoKats Automated Test Drive Code Greg McCoy Programming 1 16-01-2003 17:45
