Go to Post Welcome to The 2018 FIRST Robotics Competition: Bureaucracy Bash! - Andrew Schreiber [more]
Unread 03-02-2005, 13:06
Jeff Rodriguez Jeff Rodriguez is offline
Too young to be an 'old guy'
FRC #0155 (Technonuts)
Jeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond repute
Send a message via AIM to Jeff Rodriguez Send a message via Yahoo to Jeff Rodriguez
Re: pic: The Robonaut's Robot
Originally Posted by MasonMM
The whole upper body is mounted on a turret powered by a chip motor. On top of the turret is a telescoping lift system that goes up and down. The Arms coming off the lift go up to about a 45 degree angle and back down to horizontal. Out of the tips of the arm, are pnumetically powered spears that we will use to catch the tetras, off the ground and off the loading stations. We will use the lift to get higher, and then raise the arms, and while hovering the tetras over the goals we will retract the spears(they are shown retracted in the picture) and the tetra will fall on the goal.
So, you can cap 2 goals at once? Amazing!!
Could this be the robot I dreamed about?
173, student: 1999-2002
173, mentor: 2005-2010
155, teacher: 2011-
Unread 03-02-2005, 13:09
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Why does it look like the arms are mounted to the bottom of the last stage of the lift? If thats because of size requirements, why does the stage continue past the arm mount points?
Team 1257
Unread 03-02-2005, 13:14
Ryan Foley Ryan Foley is offline
FRC #5687 (The Outliers)
Ryan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond repute
That is amazing, both the robot and the amount of time you have left. I love the swerve drive, turret, wow.
Amazing job. Ironic though, my former team (350) was considering the same lift with 2 arm design that you have.
Great robot, can't wait to see it in action. What regionals are you going to (so I know which section of SOAP to look at for a video of your bot)?
Ryan
FRC #5687: The Outliers [2015-?]
FRC #1995: Fatal Error [2007-2009]
FRC #350: Timberlane Robotics [2001-2004]
FRC/FLL volunteer since 2005
Unread 03-02-2005, 14:02
Joe Matt's Avatar
Joe Matt Joe Matt is offline
Wake Up Get Up Get Out There
Joe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond repute
I guess this is the time every team starts to hit their forehead and scream, "I CAN'T BELIVE I DIDN'T THINK OF THAT!"
Great robot, you're going to be on my short list for watching.
Unread 03-02-2005, 14:09
abeD's Avatar
abeD abeD is offline
FRC #4707 (Mentor FRC#4707 Alumni FRC#710)
abeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to behold
Let me see if I understand correctly:
2 Cims to drive 4 modules (or 2?) with the globe doing the steering for all 4
1 Cim for the turret
2 Pistons on each of the arms for spears. 2 Other pistons to raise/lower the arms. and 1 or 2 more to telescope?
Am I missing anything?
Btw sweet looking bot, looks very versatile.
Penn Class 08
Unread 03-02-2005, 14:13
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
i hope you will have a better way to protect that battery from getting damaged and potentially thrown out of thew robot. other then that it looks great and hope to see ya at a regional that we attend!
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Unread 03-02-2005, 14:36
MasonMM's Avatar
MasonMM MasonMM is offline
AKA: Mason Markee
FRC #0118 (Robonauts)
MasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond repute
Good guessing, but not quite.
We have 3 Cims, powering 3 wheel boxes, the forth wheel box has nothing giving it power so it just turns and goes along.
The steering is driven by a Van Door motor.
1 cim is powering the turret, through some major gearing.
The lift goes up and down with string and spool powered by 2 Ficher Price motors.
You got the pnuematics right on the arms, 2 used to flap the arms up and down and 2 used for a spear to go in and out.
Unread 03-02-2005, 14:39
MasonMM's Avatar
AKA: Mason Markee
The battery is velcroed in there so it stays pretty well, but i'm pretty sure our final design will protect it a little better as so the battery connector isn't out in the open.
Unread 03-02-2005, 14:42
tiffany34990 tiffany34990 is offline
tiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond repute
Send a message via AIM to tiffany34990
wow!!! great job you all--I'm amazed
so your lift extends 7 feet that's nice. how is your record for capping?? how fast does it go??
great job though- I'm glad you guys have time to tweak everything to make it perfect. congrats on finishing early.
Unread 03-02-2005, 15:09
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Wait, FINAL design? You mean this isn't the final thing!?!?!?!?!?!?!?
You guys are absolutely insane
2001-2004: Team 100
2006-Present: Team 254
Unread 03-02-2005, 15:37
pakrat pakrat is offline
Rich Ross
no team (The Rat Pack)
pakrat is just really nicepakrat is just really nicepakrat is just really nicepakrat is just really nicepakrat is just really nice
Send a message via AIM to pakrat
Wow, good job.
Unread 03-02-2005, 16:34
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Hey now! Not every team is doing that.
--Madison--
...down at the Ozdust!
Unread 03-02-2005, 17:22
David Lantz's Avatar
David Lantz David Lantz is offline
None #0118
David Lantz will become famous soon enough
I'd say that our top speed is 15 ft/sec. As for capping I don't believe we have a record time yet.
Those who say it cannot be done should not stand in the way of those who are doing it.
-Someone Famous
Unread 03-02-2005, 19:06
Karthik Karthik is offline
VEX Robotics GDC Chairman
Karthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond repute
*Round of applause*
Fabulous robot. I'm always intrigued when I see any sort of swerve drive. Considering how much weight it takes to swerve, it makes your elevator and arms an even greater accomplishment. All that coupled with the fact that you're close to being done this early into the build. I'm amazed! Congratulations.
You've clearly wet the appetite of many with this picture. Any chance you'll serve up some video.
:: Karthik Kanagasabapathy ::
"Enthusiasm is one of the most powerful engines of success. When you do a thing, do it with all your might. Put your whole soul into it. Stamp it with your own personality. Be active, be energetic, be enthusiastic and faithful and you will accomplish your object. Nothing great was ever achieved without enthusiasm" -- R.W. Emerson
My TEDx Talk - The Subtle Secrets of Success
Full disclosure: I work for IFI and VEX Robotics, and am the Chairman of the VEX Robotics and VEX IQ Game Design Committees
Unread 03-02-2005, 21:12
Joe Matt's Avatar
OoooooOOOOoooo, I guess that's a teaser M?
Best Robot Ever(again) Corey Balint General Forum 26 04-08-2004 23:03
pic: Robot? What Robot? CD47-Bot Robot Showcase 13 10-04-2004 07:08
pic: 294's First Inventor Robot (pic 1)... CD47-Bot Robot Showcase 4 10-03-2004 19:34
pic: Closeup of the robot hanging on robot CD47-Bot Extra Discussion 16 09-03-2004 18:27
team 25 robot pic nuggetsyl Robot Showcase 12 21-02-2004 00:57
