Go to Post All we know is the "Oh my God, No data/Radio...reset...reset" dance before our matches! - tenfour [more]
Unread 03-02-2005, 17:28
AK1 AK1 is offline
#0820 (DeltaTech)
AK1 is an unknown quantity at this point
Killough platforms (A.K.A Holonomic/kiwi drive)
My team, 820, has built a killough platform. We're having serious issues with programming the robot. The robot doesn't seem to go straight and it rotates while straffing. In addition the wheels turn faster when the motors are going in a clockwise direction than when they spin counter clockwise. We think it might be due to the pulsing but we're not sure, we also strongly suspect that its a problem with programming.
Long story short we're looking for anyone out there who has either programmed one of these before or has some ideas on how to fix the problem please reply to the post or if ur feeling very generous you could email me a copy of the code at Tcru00@hotmail.com
Your help is greatly appreciated.
Arthur
DeltaTech
Team 820
Unread 03-02-2005, 17:40
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Re: Killough platforms (A.K.A Holonomic/kiwi drive)
I've never programmed one for the RC, but I have for LEGO.
The first thing I'd say is that the motors that come with the kit have a prefered direction, meaning they spin better one way than another, which is why you get the clockwise vs. counter-clockwise thing. (All motors have this problem, but for really good ones, the difference is neglible.) This is also the reason you don't go straight, even though the same value is being sent to the motors which are currently driving you.
There are two ways to correct this. The first involves some semi-complicated programming because you create a PID loop. The idea of this loop is that it will monitor your wheel rotations (using encoders or some such thing) and if anything disturbs the speeds from the values you request, such as a bump or one motor running slower than the other, it will adjust the outputs automatically.
The other way is to use encoders (or some other method) to measure the difference in the motor speeds and hard code that into your program. Obviously, it isn't as elegant and is harder to change when you motors get more broken in (or broken ), but it's fast and easy... Actually, with a Killough, it may be just as difficult to do, because you must store the differences between all (3? I'm assuming a normal setup) the motors and choose the right one to use for which ones you are currently running.
Hope that helps!
P.S. What motion exactly are you refering to when you say straffing? One motor on full? Two? Two at differing speeds? Maybe I'm just not thinking right now...
Unread 03-02-2005, 17:54
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
I don't know much about kiwi drive, other than watching the original video and the 229 parody, but maybe I can still help you.
The vast majority of DC motors are designed to run more efficiently in one direction. This is a function of how the motor is wound. This difference was very drastic in the drill motors last year; I haven't found it to be as severe in the CIMs this year. If I had to fix this in software, I would take a CIM motor, and hook it up to a Victor. Pick a few different clockwise PWM values, and measure the speed with a tachometer (you can make your own with an encoder). Then output the equivalent values to spin the motor counterclockwise. Keep note of the speeds, and then do a calculation to slow the motor when it's running clockwise. For example, if the motor runs twice as fast clockwise as counterclockwise (a gross exaggeration):
if(pwm15>127)
   pwm15=(pwm15-127)*.5+127;
Hope this helps.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 04-02-2005, 15:13
I beleive it took 1083 several regionals before they were able to get thier robot driving straight last year.
Unread 04-02-2005, 15:42
Adam Krajewski's Avatar
Adam Krajewski Adam Krajewski is offline
AKA: Jewski
None #0857 (Superior Roboworks) / Team #0068 (Truck Town Thunder)
Adam Krajewski is on a distinguished road
The way we controlled our Killough platform back in 2002 was a completely analog solution. We used three joysticks mounted in the same orientation as the drive wheels (120 degrees apart), mounted together using ball joints like so:
This was back in the PBASIC days. It may be low-tech, but it certainly worked: http://stuweb.ee.mtu.edu/~alkrajew/FIRST/kiwi.mpg
"My favorite programming language is solder."
- R A Pease
Unread 04-02-2005, 16:04
Originally Posted by Adam Krajewski
Wow. Just...wow. $@#$@#$@#$@#, that's awesome. The forums don't like the words going through my head as I see this, but I can't find better ones to replace them.
Unread 04-02-2005, 18:20
MattB703 MattB703 is offline
AKA: Matt
None #0703 (Team Pheonix)
MattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud of
In my dream of a 4 wheeled Killough drive bot I was going to turn the handle of a joystick to 45° from the base of the joystick. If you push the joystick strait up you get full + X and full + Y. You can map the drive motors directly to the joystick values in such a way that the bot moves in the direction that the joystick is pressed. You would also need a rotary pot to control the rotation of the bot.
Unread 04-02-2005, 19:52
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
I did this last year. It worked, but I couldn't get used to the way the joystick felt in my hand. I had a hard time moving the stick along the diagonal when going straight forward and reverse.
I used the joystick thumb wheel for this (NOT the trim wheel!). Again, it worked, but I didn't like it because it didn't self center when released.
Unread 04-02-2005, 21:36
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
as adam already posted the analog joystick solution is very easy to construct and works flawlessly without any programming....i repeat, no programming!
my suggestion is to build one and then work on a slick programming solution if you still feel it's necessary.
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Globe gear box Pat Roche Motors 9 25-05-2004 22:50
Pressure on Drive Team David66 General Forum 52 30-03-2004 14:31
What is wrong with this code???? It won't Compile and I don't know why? Please Help CrashZero Programming 23 26-03-2004 09:44
what's your most important drive train advice? Ken Leung Technical Discussion 42 07-01-2003 09:58
