Go to Post Inspiration is a two-way street. - Taylor [more]
Unread 02-02-2005, 22:16
DinkyDogg DinkyDogg is offline
DinkyDogg is an unknown quantity at this point
Reflective materials?
I know how to make it glossy or shiny (specularity), but how can I make a material actually reflect the other objects in the scene? I imagine I must be missing something somewhere, please let me know.
Thank you!
-Jake
Unread 02-02-2005, 22:21
MConte05's Avatar
MConte05 MConte05 is offline
"Operation FIRST"
AKA: Matt Conte
#1098 (G.I.'s)
Team Role: Driver
MConte05 is on a distinguished road
Send a message via AIM to MConte05
Re: Reflective materials?
Under the "reflection" channel in the material editor, select that and choose either raytrace I believe or else "flat mirror".
Unread 03-02-2005, 17:49
I'm afraid I can't find teh reflection channel. Could you describe what it is exactly I am looking for or where to find it? Thanks!
Unread 03-02-2005, 18:08
MConte05's Avatar
"Operation FIRST"
AKA: Matt Conte
#1098 (G.I.'s)
Team Role: Driver
Press "M" to bring up the material editor.
Select the "Reflection" Channel and click on "none"
Then select "Flat Mirror"
I have highlighted what you need to do, this is in 3dsmax7
http://img207.exs.cx/img207/7259/max.jpg
Hope this helps
Unread 03-02-2005, 18:24
Thank you very much! I couldn't have asked for more detailed instructions! I'll do that now.
edit- Okay, i've tried it, but it still doesn't work. Do I have to mess with some settings in the reflection > flat mirror map properties? :-/
Unread 04-02-2005, 00:10
MConte05's Avatar
"Operation FIRST"
AKA: Matt Conte
#1098 (G.I.'s)
Team Role: Driver
Could you post a screen of your settings? As well as the other material properties you have on them.....
Unread 07-02-2005, 23:18
Tristan116 Tristan116 is offline
3dsMax Deity
#0116 (Epsilon Delta)
Team Role: Animator
Tristan116 is an unknown quantity at this point
Send a message via AIM to Tristan116
The easiest way out.... is of course to just open the raytrace material library that max comes with. At which point you can see how those work.
In your material editor, click that box that say "standard" (this is the type of material button thing...) then click "mlt Library" under "browse from" Then hit open.. and choose "Raytraced_01" or 02.. whatever. But those are pure reflective materials so make sure you play around with the falloff/decay settings and such to get a realistic effect.
Unread 10-02-2005, 22:57
Burne S's Avatar
Burne S Burne S is offline
The Bored One...who is Doomed!
AKA: Kyle
#1622 (Spyder)
Burne S is on a distinguished road
And if that's still hard, try making an "Architectural" material. There's a Drop-Down list with all kinds of types, like "Metal-Polished" for example.
Play around with the different settings to see what you like.
~Burne
Newbies never looked so cool...
Unread 11-02-2005, 08:34
Baden3DMAX13's Avatar
Baden3DMAX13 Baden3DMAX13 is offline
IUPUI Student/ 3D Animator
None #0393 (Full Metal Jackets)
Baden3DMAX13 is on a distinguished road
Send a message via AIM to Baden3DMAX13 Send a message via MSN to Baden3DMAX13 Send a message via Yahoo to Baden3DMAX13
ok, depending EXACTLY on what you want to put a reflection on, you could use many different methods... if you want to make something look more realistic when you have a reflection on it go to your material editor(m) and go up to button that says standard, click on it and go down to raytrace, once you've done this go into the basic parameters rollout and go to reflect, click on the little square next to it to apply a map to it. When the screen comes up select fall off, once selected it brings up the properties for the map. While in the properties go to falloff type where it says perspective\parallel and go down to fresnel. Fresnel falloff is a more lifelike falloff that adjusts to how you look at it from your view\viewport. Apply the material to an object and if you're going for the metal look, go back into the material's basic parameters and change the material type from blinn(i think that's the standard) to metal and mess around with the diffuse and specular maps\colors\values and also the glossiness... If you have any questions, i'd be happy to answer them. I hope that I helped you out a little bit
Out of all the things I've lost, I miss my mind the most. - Ozzy Osbourne baby!!!
Fiat 500 (WIP) <~~Check It Out!!!!
Materials Jeff K. General Forum 11 22-01-2005 02:24
materials nick_champ_2 General Forum 7 05-02-2003 20:02
How is reflective tape applied to HP crates? Dr.Bot General Forum 2 06-01-2003 15:17
additional materials Penn Robotics Off-Season Events 1 01-11-2001 23:25
Additional allowed materials kmcclary Off-Season Events 3 11-10-2001 13:05
