Go to Post I think AndyMark just sold out of rabbits feet. - BRAVESaj25bd8 [more]
Unread 03-02-2005, 16:34
DukesAZ DukesAZ is offline
President Brophy Robotics
#0991 (The Dukes)
Team Role: Electrical
DukesAZ has a spectacular aura aboutDukesAZ has a spectacular aura about
2003 Gyro Wiring Harness
Does anybody know where we can pick up the wiring harness for the 2003 BEI Gyro? Apparently you were supposed to order it seperately but we haven't found a disturbutor that carries them.
Thanks,
The Dukes
The Dukes
2004 Arizona Imagery Award Winners
2004 Los Angeles Entrepreneurship Award Winners
2005 Arizona Regional Finalists with 987 and 1212
2005 Vegas Finalists with 1425 and 359
Unread 03-02-2005, 17:00
Ricky Q.'s Avatar Unsung FIRST Hero
Ricky Q. Ricky Q. is offline
yee haw!
FRC #0148 (Robowranglers)
Ricky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond repute
Send a message via AIM to Ricky Q.
Re: 2003 Gyro Wiring Harness
Are you planning on using the 2003 gyro? It appears to not be legal because of its cost:
Originally Posted by FIRST Q&A
ID #1118
Q:Can we use Gyros from previous year's kits on our robot?
A:Yes as long as it passes the 2005 Part Use Flowchart and you account for its cost according to the cost accounting rules.
But:
ID #1318
Q:From ID 1118: The Gyros from previous year's kits appears to cost $300USD and therefore exceeding <R44> limit of $200USD for electronic components. (http://fastascent.com/Projects/Attit...te_gyro_s.html)
A:If that is the price, clearly R44 excludes them from being used. Find a used BEI gyro or find a cheaper gyro of another brand.
Just a heads up.....
Ricky Quinones
Director of Sales - VEX Robotics
Unread 03-02-2005, 18:03
SpaceOsc's Avatar
SpaceOsc SpaceOsc is offline
16 Years of FIRST!
AKA: Oscar Vasquez
FRC #4501 (Humans)
SpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant future
Send a message via AIM to SpaceOsc Send a message via Yahoo to SpaceOsc
Question Re: 2003 Gyro Wiring Harness
our team never used our gyros soo we have several
my question is does anyone know which gyros belong to which year?
model numbers would be nice....
but also there a physical differece to them in the connector section, one u feed a connect thru the side and in another u feed the connector from the top, which is from '03 and which are from before that? there both bei and i want to seee if there a cost difference to them.
thanks in advance
-Osc-
2014-2017: Team 4501 Coach/Lead Mentor
2002-2011: Team 702, Mentor
2001-2002: Team 702 Captain
Unread 03-02-2005, 18:20
We are using an old BEI gyro for testing, while we wait for our AXDR150EB to come in from analog devices. We also do not have the connector, and found the best way to connect it was to either use a pwm cable across the top and bottom rows, then splice it at the other end and solder the wires in the correct order. If you dont want to waste pwm cables, rip some header cables out of an old PC. Two 3 prong females (1 for gyro, 1 for RC), and a 1 prong female (for top row of gyro connections) should do the trick.
Updated: Example Gyro Interface Code Kevin Watson Programming 2 28-03-2005 04:36
Example gyro code released. Kevin Watson Programming 60 17-03-2005 18:32
Gyro Troubles SteveO Programming 13 30-01-2005 16:46
The Science Channel to broadcast FIRST documentary Andy Baker General Forum 49 01-03-2004 14:03
2003 gyro datasheet Rickertsen2 Electrical 1 09-12-2003 00:47
