Go to Post If you can't be bothered to read the Q&A, why are you spending thousands of dollars competing? - Ian Curtis [more]
Unread 03-02-2005, 22:54
DarkJedi613's Avatar
DarkJedi613 DarkJedi613 is offline
Running Riot
AKA: Patrick Cloke
FRC #0358 (Hauppauge Robotic Eagles) FRC #1493 (RPI/Albany High School)
DarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to behold
Send a message via AIM to DarkJedi613 Send a message via MSN to DarkJedi613 Send a message via Yahoo to DarkJedi613
Re: Blown Victors - WHY?
Originally Posted by wmurphy
Just curious - do you know the FET part #s and a good source for them? Thanks!
I do in fact - I just have to find it.
From DigiKey: IRL3103-ND
($1.64 ea., $1.16 per 10, $.96 per 100)
Mouser also has them (search for IRL3103)
Also we know for sure that we got metal shavings in when we blew them - we took them out when we took the Victor apart.
I'm going to attach a PDF spec sheets if you want to check it out yourself. (The Victor fet specs are too large to attach, but I'll email it to anyone who wants it.)
2003 - 2006 President, Coach, Webmaster Team358.org
2008 Mentor, Team 1493
Team Search | (Updated: 1-16-08)
FIRSTsearch
Unread 04-02-2005, 07:30
Originally Posted by roboticsjenkins
They blew because you probably grounded the Victors out because I had that problem last year. It's better to mount them on a piece of material that is not a conductor of electricity......Thats my guess
Andrew,
The case of the Victors is an insulator. We mount our electricals on a punched aluminum sheet and have never had a problem.
"From DigiKey: IRL3103-ND"
It is really interesting if you take a look at the data sheet on these little gems. http://www.irf.com/product-info/data...ta/irl3103.pdf Note under maximum ratings, that continuous current is 64 amps and pulsed current is 220 amps per device (limited by junction temperature). Remember that there are three devices in parallel for 64 x 3=192 amps as long as you can keep the little buggers cool. When teams blow these up, there is some extreme abuse occuring. High currents over long periods of time, heat and/or metal flakes in of near the devices spell destruction. Changing FETs is not a guaranteed fix, other devices may be destroyed when a FET(s) short.
Please note that the Drain and the tab of the package are connected together. That means that the tabs of half of the FETs in the victor are connected to battery positive and the tabs of the other half are connected to motor positive. Keep conductive material away from the FETs.
Unread 04-02-2005, 08:31
Running Riot
AKA: Patrick Cloke
Yeah, I know - if you blow the board its just gone (though you can save the muffin fan!).
One of our mentors created a tester to see what was wrong with the Victor, I'll see if I can get a wire diagram and pictures of it.
FIRSTsearch
Unread 05-02-2005, 18:31
Der Sichelmann's Avatar
Der Sichelmann Der Sichelmann is offline
Professional Team Member
#0358 (Eagles)
Team Role: Student
Der Sichelmann is an unknown quantity at this point
Of the victors our team has blown, the problem has always been FETs. We have been able to repair them.
24Vs and victors greencactus3 Control System 13 05-02-2005 14:22
Calibrating Victors SpaceOsc Control System 27 19-11-2004 07:59
Victors for Chips Cutting Off aaronbr28040 Control System 13 20-02-2004 16:52
Flakey Victors archiver 1999 4 23-06-2002 21:58
DON'T Recalibrate Victors! Joe Johnson Off-Season Events 0 12-11-2001 22:58
