Go to Post If you want to have other teams cheer for you all day long at competition, name your team "Robot Coming Through". - Gary Dillard [more]
Unread 04-02-2005, 01:39
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Re: Modifying Parker Cylinder
From rule <R85>:
Pneumatic components supplied in the Kit compressor, regulators, pressure switches, cylinders, valves, fittings, tubing, etc.) may not be modified except as follows: ... Mounting and connecting pneumatics components using the pre-existing threads, mounting brackets, etc., is not considered a modification of the components. Removing the pin from the rear of an air cylinder is allowed as long as the cylinder itself is not modified.
So, yes, you can remove the mounting pin. However, if you are going to place the cylinder on the output shaft of the van door motor (in the place of the pin), then be sure that you are properly supporting the output shaft itself against excessive side loads (i.e. support the shaft on both sides of the cylinder if it will be pushing against the shaft) and rotational friction problems (i.e. protect the output shaft in the mounting pin hole from rubbing directly on the hole without an appropriate bearing surface).
-dave
Mulit-postioning with pnuematics this year? KenWittlief Pneumatics 101 01-02-2005 21:54
Making a series of spaced holes around a cylinder in inventor James114 Inventor 13 21-11-2004 18:44
Need Inventor model 3/4" Bore Cylinder Quick sanddrag Inventor 1 05-04-2004 00:40
Is 'using a smaller cylinder' really that easy?? mjt902 Pneumatics 4 29-01-2003 16:13
Stopping a Piston... Dan 550 Technical Discussion 7 02-02-2002 11:36
