#8
Re: Yes another autonomous question.
All you have to do is short the 2 pins, so yes... by wiring a button to the 2 pins for autonomous will allow you to easily turn on and off the autonomous mode using the button. Like Alan said, be VERY careful that you wire the right pins or you could do serious damage to the controller.
| A little question about the autonomous mode | Anton | Programming | 4 | 18-01-2005 14:08 |
| Autonomous testing question | tml240 | Programming | 8 | 24-02-2004 16:12 |
| question about autonomous timing | zainali | Programming | 6 | 23-02-2004 22:58 |
| autonomous mode problem on field | Chris_C | Programming | 17 | 26-03-2003 19:11 |
