Go to Post I don't know about you but i would love to have a grilled cheese maker in the workshop. - CMBrandon [more]
Unread 03-02-2005, 01:58
Wizang Wizang is offline
Wizang is an unknown quantity at this point
Yes another autonomous question.
I understand where to put the autonmous code in the code, and that the competition port will be used to activate that function at the competition, but I have another question. Would anyone suggest a good way to test the autonomous code we create before the games. Is there anyway to emulate First's controll throught he competition port? Or are we limited to testing our code in a different function besides the actual autonomous? Any help would be appreciated. Thanks.
Unread 03-02-2005, 02:02
NoodleKnight's Avatar
NoodleKnight NoodleKnight is offline
24 Hours of LeMons?
FRC #0100 (WHS&CHS Robotics)
NoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud of
Send a message via AIM to NoodleKnight
Re: Yes another autonomous question.
I think setting your team number to 0 on the OI triggered autonomous. There are diagrams for a competition port faker which can simulate autonomous mode. Try doing a search.
WHS/CHS Robotics - Team 100 (2003-2006):
2006- Delphi's Driving Tommorow's Technology @ Davis | Imagery Award @ SVR | 2004- SVR Finalists (w/ 691 and 1280)| 2003- Delphi's Driving Tommorow's Technology @ Sac
Unread 03-02-2005, 07:23
Yes. There is a document on the IFI web site with exactly what you need. Search the ChiefDelphi Forums for the word "dongle".
Unread 03-02-2005, 08:39
Electrical Engineer
Rookie Year: 1995
Please see this document.
Mike Betts
As easy as 355/113...
Unread 03-02-2005, 10:25
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
It probably mentions this in the document (I'm too lazy to look), but it's important enough to merit another warning. Be VERY careful with what you connect to the Competition port. Some of the pins are connected directly to the processor, and if you connect anything to them, you will instantly fry the OI.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 03-02-2005, 11:51
The Competition Port Pinout Guide shows connections to pins 5, 6, 8, and 12 only. It says, in large bold UPPERCASE letters:
CONNECTIONS TO ANY OTHER PINS CAN DAMAGE THE OI AND WILL VOID ANY WARRANTY
Note that for the 2005 OI, grounding pin 12 to enable the alternate radio modem channels is unnecessary (but the alternate channels will only work if the team number is set to 2048 or higher).
Unread 04-02-2005, 02:50
Okay, that helps alot, thanks guys. One other question is, what to hook up to it? Will just a button activate it? Or is it something more complex? Thanks.
Unread 04-02-2005, 03:31
miketwalker miketwalker is offline
Robot Lifeguard
FRC #1902 (Exploding Bacon)
miketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond repute
Send a message via AIM to miketwalker
All you have to do is short the 2 pins, so yes... by wiring a button to the 2 pins for autonomous will allow you to easily turn on and off the autonomous mode using the button. Like Alan said, be VERY careful that you wire the right pins or you could do serious damage to the controller.
A little question about the autonomous mode Anton Programming 4 18-01-2005 14:08
Autonomous testing question tml240 Programming 8 24-02-2004 16:12
question about autonomous timing zainali Programming 6 23-02-2004 22:58
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
