Re: Modifying Parker Cylinder
<R85> allows you to remove the pin but you are not allowed to "file, machine or abrasively remove any part of an air cylinder".
So you cannot enlarge or machine for a key. You can bush if the original hole is larger than the motor shaft. You cannot machine the hole larger if it is too small. Pressing the cylinder onto the shaft 'as is' could fall under the "abrasively remove" clause. |
Make a mounting bracket to fit onto the pin then have a larger hole.
| Mulit-postioning with pnuematics this year? | KenWittlief | Pneumatics | 101 | 01-02-2005 21:54 |
| Making a series of spaced holes around a cylinder in inventor | James114 | Inventor | 13 | 21-11-2004 18:44 |
| Need Inventor model 3/4" Bore Cylinder Quick | sanddrag | Inventor | 1 | 05-04-2004 00:40 |
| Is 'using a smaller cylinder' really that easy?? | mjt902 | Pneumatics | 4 | 29-01-2003 16:13 |
| Stopping a Piston... | Dan 550 | Technical Discussion | 7 | 02-02-2002 11:36 |
