Go to Post Only time will tell for sure, but it seems that the current software providers are hatching up a pretty good solution to the problem. - dlavery [more]
Unread 04-02-2005, 08:25
Jatheon4316's Avatar
Jatheon4316 Jatheon4316 is offline
AKA: Jason
None #0500
Jatheon4316 can only hope to improve
Send a message via AIM to Jatheon4316
Post Number Variables Gone Bezerk!
My team has run into a little difficulty....
Whenever we try to use floats, longs, doubles, or anything else besides integers...our robot does all kinds of weird things it shouldn't be doing...
As long as we use int's, our coding runs the way it should...however, it would be very nice if we didn't have to round everything of to an integer!
HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Unread 04-02-2005, 08:45
Electrical Engineer
Rookie Year: 1995
Re: Number Variables Gone Bezerk!
Please read this thread.
Mike Betts
As easy as 355/113...
Unread 04-02-2005, 12:48
prograid's Avatar
prograid prograid is offline
AKA: Ben Cherian
prograid will become famous soon enough
That thread is about floatingpoint operations. I don't think it applies to longs and stuff.
In reply, to the first post, It may be possible that you are running out of memory because of using too many floats, longs, doubles, etc. Can you use chars? If not then something is really wrong, because your pwms are chars.
Unread 04-02-2005, 13:08
AKA: Jason
None #0500
When we tried to use ints (to print the joystick's x and y axis values onscreen) we had nothing but the default code and those few lines! ---Later though I realized that we were putting "%i" in the printf statements, only "%d"s are supported!
The other times we've had problems so far also have been with the default code and only a few extra variables...
Note: We're using the team robot from last year (2004) to test our coding on...could some kind of conflict (between 05 MPLAB+default code and the 2004 robot) be causing the trouble? The idea of doing trig functions and accurate autonomous navigation with only ints and chars is not very nice...
Unread 04-02-2005, 13:28
One word: CORDIC.
Need help with Variables ? David Bryan Programming 5 23-02-2004 07:42
Help On Coding 2K1 Controller GregTheGreat Programming 9 05-12-2003 18:35
team number... Ken Leung Chit-Chat 39 28-09-2003 14:36
VB Program to monitor robot variables DanL Programming 7 15-02-2002 22:35
WASH scouting fields Mike Soukup Scouting 0 04-02-2002 02:39
