Go to Post This reminds me a lot of how millennials are regularly called out for simply being younger and having different perspectives. In the end it's the ones who are calling them out in unprofessional in ways that end up embarrassing themselves and looking uninformed. - Karthik [more]
Unread 02-04-2005, 09:14 AM
Matthew_H's Avatar
Matthew_H Matthew_H is offline
Ubergeek
#1028 (Ubergeeks)
Matthew_H will become famous soon enough
Send a message via AIM to Matthew_H Send a message via MSN to Matthew_H
Re: Default code and the Compressor
Originally Posted by Mike Betts
Matthew, et al,
I was planning to hook up a compressor this afternoon anyway. I will try the 2005 default code and report my observations.
Mike
We finally got it to work. We changed this the code below and it worked. Please explain why this worked.
relay8_fwd = !rc_dig_in18;  /* Power pump only if pressure switch is off. */
relay8_rev = 0;
relay8_rev = !rc_dig_in18;  /* Power pump only if pressure switch is off. */
relay8_fwd = 0;
Matthew
Unread 02-04-2005, 09:27 AM
Electrical Engineer
Rookie Year: 1995
relay8_rev = 0;
Matthew,
relay8_rev must have been initialized to 1 (or set to 1) somewhere in the code or possibly it was never initialized (an uninitialized variable is, by definition, undefined).
Anyway, congrats on getting it working...
Mike
Mike Betts
As easy as 355/113...
Unread 02-04-2005, 09:53 AM
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
Keep in mind that you're not supposed to run the compressor backwards - make sure that, if you have the spike in reverse, you switch the leads on the compressor or something.
Shift to the left, shift to the right!
Pop up, push down, byte, byte, byte!
Unread 02-07-2005, 07:19 AM
stephenthe1 stephenthe1 is offline
stephenthe1 is on a distinguished road
yeah, mine won't work either. much more importantly, 2.4 won't even take input from our joysticks, yet 2.2 will. these are both unmodified. any suggestions?
Help On Coding 2K1 Controller GregTheGreat Programming 9 12-05-2003 06:35 PM
Chassis Material/Construction sanddrag Technical Discussion 51 12-05-2003 12:59 PM
New software?? mjt902 Programming 2 01-08-2003 10:40 AM
PBASIC 2.5 answer from Parallax JasonS Programming 6 01-07-2003 07:21 PM
Team 237 unleashes a "Beast" Elgin Clock Robot Showcase 5 03-27-2002 09:09 PM
