Go to Post Design is iterative, right? - JesseK [more]
Unread 04-02-2005, 12:00
Rob Rob is offline
AKA: Rob
FRC #0131 (CHAOS)
Rob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond repute
Send a message via AIM to Rob
Re: Low-Rider Robots
Originally Posted by HPA_Robotics_13
Team 121: do you guys have .25 counting those bolt heads?
We bought flathead bolts and countersunk all of the heads that were on the bottom of the chassis so they are flush with the bottom. This is pretty easy to do and will solve your problem.
Hope this helps!
Rob
P.S. your setup should work great if you are powering all four wheels, you will have to do testing to determine if there is enough traction to manuver with only 2 powered wheels (its probably fine though)
Driving Robots under/into the Goals ... allowed? erniep Rules/Strategy 8 11-01-2005 22:32
Robots doing origami! RoboMom Math and Science 4 24-10-2004 19:42
Robots Doing the Dirty Work! Brandon Martus Announcements 2 23-06-2004 12:31
Robots compete in first match (FitN) Clark Gilbert FIRST In the News... 0 24-03-2004 18:11
FYI: FIRST Robots at the NYC Hall of Science Rich Wong General Forum 9 11-07-2002 10:52
