Go to Post If it gets people talking about not only robots but science and technology, it's all good. - Koko Ed [more]
Unread 04-02-2005, 13:48
gnormhurst's Avatar
gnormhurst gnormhurst is offline
Norm Hurst
AKA: gnorm
#0381 (The Tornadoes)
gnormhurst will become famous soon enoughgnormhurst will become famous soon enough
syntax error using enum{}
When I compile my code, the compiler says "syntax error" for one of my header files and points to the line shown below:
enum
  START,     <==  this line causes syntax error
  IN_PROGRESS,
  DRIVING,
  TURNING,
  COMPLETE
When I rename the variable START to something else like FOOSTART, the error moves down to the next line:
enum
  FOOSTART,
  IN_PROGRESS,  <===  now the error is here
  DRIVING,
  TURNING,
  COMPLETE
I figured there must be a name conflict (since I'm using bits of Kevin's code), so I Searched in Project Files... for "IN_PROGRESS", but it is only defined in this one place. No conflict. As I modify each variable in the list, the error moves down the list.
I did a Build All (CTRL-F10) to make sure there wasn't a leftover symbol table. No difference.
As a matter of practicality I renamed all the variables to start with an _underscore, and now it builds just fine. But it bugs me that I can't explain this error.
Any ideas?????
Here's the entire header file:
#ifndef SCRIPTING_H
#define SCRIPTING_H
#define MAX_SCRIPTS 32 // more than this is an error from parseScript()
struct scriptCommand
  int command;
  long int parm_1;
  int parm_2;
  int parm_3;
// List of commands
enum
  S_NAME,    // marks the start of a script
  S_END,     // marks the end of a script
  S_DRIVE,   // <distance>, <maxSpeed>, <maxAccel>
  S_TURN,    // <heading>, <maxSpeed>, <maxAccel>
  S_STOP,
  S_WAIT,    // <counts>
  S_SET_ARM_POSITION,  // <angle>, <speed>, <tolerance>
  S_LIST_END
// List of all possible command states
// Not all are used in every command.
enum
  START,
  IN_PROGRESS,
  DRIVING,
  TURNING,
  COMPLETE
int parseScript();
int startScript( int scriptCode );
int executingScript( );  // returns 1 if a script is executing.
void backAndForth();
void driveFromStartToLoading();
void knockOffHangingTetra();
void setArmPosition();
unsigned char sDrive();
unsigned char sTurn();
#endif
Trenton Tornadoes 381
2004 Philadelphia Regional Winners
2006 Xerox Creativity Award
My corner of the USPTO.
My favorite error message from gcc: main is usually a function
My favorite error message from Windows: There is not enough disk space available to delete this file.
Unread 04-02-2005, 13:56
Matt Leese Matt Leese is offline
Been-In-FIRST-Too-Long
FRC #1438 (The Aztechs)
Matt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond repute
Send a message via AIM to Matt Leese
Re: syntax error using enum{}
For one, enums aren't part of the C standard (unless they were add in ISO C99). Second, you have to give the enum a name. I believe the syntax is:
enum <name> {
<enum values>
Hope this is helpful.
Matt
Unread 04-02-2005, 14:18
gnormhurst's Avatar
Norm Hurst
AKA: gnorm
enum <name> {
<enum values>
According to my copy of K & R Second Edition (ANSI C Edition) enumerations are defined in Appendix A (Reference Manual) section A8.4. The identifier (what you show as <name>) is indicated as optional.
Besides, if enum{} wasn't allowed, just changing the names of the identifiers would not have eliminated the syntax error. But it did.
I'm still confused.
Unread 04-02-2005, 15:25
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
I'm still confused.
All of those identifiers are #defined in robot.h:
/* Command States */
/* These states are used by the commands to keep track of the robot's
   progress in completing each command. */
#define START              1
#define IN_PROGRESS        2
#define COMPLETE           3
#define TURNING            4
#define DRIVING            5
#define STOPPED            6
I think this explains the mystery.
"Find in Project Files" only searches files it knows about in the project. (i.e. listed in the project window), whereas, the compiler couldn't care less about the files in the IDE's list. It cares about #include statements only.
Unread 04-02-2005, 16:02
gnormhurst's Avatar
Norm Hurst
AKA: gnorm
I think that's it. I had re-written robot.[h,c] but I think I have a residual #include "robot.h" in user_routines.c. I'll have to double check tonight, but I'm pretty sure that's it.
You'd think the compiler could have said something a little more helpful than "syntax error"...
Thanks!
-Norm
Unread 04-02-2005, 16:38
Anton's Avatar
Anton Anton is offline
Anton Povzner
#1581 (Element)
Anton can only hope to improve
Smile Re: syntax error using enum{}
I can only agree with you about the error statement. I wasted hours trying to decipher these, while the problem was mainly as simple as giving a name to a parameter similiar to an existing macro, or ; being where it's not needed and vice versa
Unread 07-02-2005, 09:40
gnormhurst's Avatar
Norm Hurst
AKA: gnorm
That was indeed the error.
Yeah, the compiler is low on helpfulness. I accidentally created a local variable that shadowed a global variable but it gave no warning.
Is there a way to increase the number of warnings for the compiler? Like gcc -Wall?
Unread 07-02-2005, 11:07
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Agreed, but keep in mind what was happening: your "enum" values were being replaced with the #defines from robot.h, so to the compiler your enum ended up looking like this:
enum
  1,
  2,
  3,
  4,
  5
While that doesn't excuse the cryptic error generated, it might at least make sense why the compiler reported a syntax error (because it is!).
Unread 07-02-2005, 14:25
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
You can set the message level: Project | Build Options | Project
Then on the MPLAB C18 tab, set the Diagnostic Level="Errors, Warnings, and Messages"
I make no guarantee, however, that it will catch these problems.
Routine declaration syntax error (Or: Where's wlado?) Astronouth7303 Programming 15 24-03-2004 05:51
BS2 syntax (PBASIC) on the new controllers? Maybe! Jeremy_Mc Programming 0 25-10-2003 15:00
PBASIC Syntax Question Raven_Writer Programming 4 20-08-2003 08:07
PBASIC language syntax WizardOfAz Programming 14 30-04-2003 10:23
UltraEdit Syntax Highlighting Jeff McCune Programming 9 19-01-2003 20:08
