Go to Post CD would not be what it is without Brandon - Richard Wallace [more]
Unread 04-02-2005, 07:24
Anton's Avatar
Anton Anton is offline
Anton Povzner
#1581 (Element)
Anton can only hope to improve
gyro/accelecometer/limit switch help needed
Please, people, I need some help.
What is each of the above, what are the uses for them and their limits.
Also, I've been looking for a neat way to swithc autonomous startegies on the spot, but I couldn't think of anything more neat than just using digital inputs as they are.
If you have the time, please help.
Unread 04-02-2005, 16:17
Anton's Avatar
Anton Povzner
#1581 (Element)
Also, I've been looking for a neat way to switch autonomous startegies on the spot, but I couldn't think of anything more neat than just using digital inputs as they are.
btw- first I posted this in electrics forum, got really surprised when I saw that it's not in here programming one.
Unread 04-02-2005, 16:26
Re: gyro/accelecometer/limit switch help needed
Anton, every single one of these questions has been answered before in multiple other threads. I'd suggest you use the search function.
Your search results might be better if you spell accelerometer correctly, though.
Unread 04-02-2005, 16:32
auditt241 auditt241 is offline
FRC #0241 (The Astros)
auditt241 is an unknown quantity at this point
Well an accelerometer detects a tilt of the bot. They can determine if you robot has been moved and can reset it to its original spot. For example, if your bot was driving and you got hit the accelerometer would autmatically determine it moved and it would reset it to your original location. With an accelerometer it must be exactly level or else it won't work right. You need a plot chart with a G force speed and it senses the acceleration and with this info (in theory) it can determinme how much a robot has moved, and correct it self to its original position. A Gryo senses lateral motion and can detect wihcih angle in reference to your original position. Its pretty much a gryoscope in a big box. And im sorry I dont know what a limit switch is.
Me: "Dude I built a robotic arm today"
Friend: "Why don't you go build a robotic life?"
Unread 04-02-2005, 16:39
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
you can find some help in the following thread:
http://www.chiefdelphi.com/forums/sh...ad.php?t=33430
-Michael Dessingue
PRESSURE SWITCH Mr. Steve Pneumatics 20 01-12-2005 10:20
LEDs in switch box. ZZII 527 Electrical 5 06-03-2004 19:39
Digital Inputs interfering with each other Bongle Programming 8 23-02-2004 11:18
OI jog switch Natedude Control System 4 22-02-2004 17:13
