Re: Killough platforms (A.K.A Holonomic/kiwi drive)
In my dream of a 4 wheeled Killough drive bot I was going to turn the handle of a joystick to 45° from the base of the joystick. If you push the joystick strait up you get full + X and full + Y. You can map the drive motors directly to the joystick values in such a way that the bot moves in the direction that the joystick is pressed. You would also need a rotary pot to control the rotation of the bot.
as adam already posted the analog joystick solution is very easy to construct and works flawlessly without any programming....i repeat, no programming!
my suggestion is to build one and then work on a slick programming solution if you still feel it's necessary. |
| Globe gear box | Pat Roche | Motors | 9 | 25-05-2004 22:50 |
| Pressure on Drive Team | David66 | General Forum | 52 | 30-03-2004 14:31 |
| What is wrong with this code???? It won't Compile and I don't know why? Please Help | CrashZero | Programming | 23 | 26-03-2004 09:44 |
| what's your most important drive train advice? | Ken Leung | Technical Discussion | 42 | 07-01-2003 09:58 |
| "Motors and Drive train edition" of Fresh From the Forum | Ken Leung | CD Forum Support | 6 | 29-01-2002 12:32 |
