Go to Post There should be no teams yelling "robot". - RoboMom [more]
Unread 29-01-2005, 18:39
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: 2005 default code won't compile
Can you give us the exact error message?
Unread 30-01-2005, 00:49
ElGeeko's Avatar
ElGeeko ElGeeko is offline
AKA: Kyle
#1375 (Megabites)
ElGeeko is an unknown quantity at this point
Send a message via AIM to ElGeeko Send a message via MSN to ElGeeko
It was a few posts before, only there wasn't a line specifically for stdio.
Originally Posted by ElGeeko
Clean: Deleting intermediary and output files.
Clean: Done.
Executing: "c:\mcc18\bin\mcc18.exe" -p=18F8520 "control.c" -fo="c:\code\code_v2.4\control.o" /i"C:\Dev-Cpp\include" /i" c:\code\code_v2.4" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
c:\code\code_v2.4\control.c:11: unable to locate 'stdio.h'
c:\code\code_v2.4\control.c:12: unable to locate 'ifi_aliases.h'
c:\code\code_v2.4\control.c:13: unable to locate 'ifi_default.h'
c:\code\code_v2.4\control.c:14: unable to locate 'ifi_utilities.h'
c:\code\code_v2.4\control.c:15: unable to locate 'user_routines.h'
c:\code\code_v2.4\control.c:16: unable to locate 'user_Serialdrv.h'
c:\code\code_v2.4\control.c:17: unable to locate 'user_routines.c'
error 1 spawning c:\mcc18\bin\cpp18
Halting build on first failure as requested.
BUILD FAILED: Fri Jan 28 00:07:44 2005
Unread 30-01-2005, 13:15
I notice you haven't corrected your typo. There's no such thing as a blankC drive.
You should probably go back to the defaults and get it compiling before you attempt to redirect everything.
In MPLAB go to Project -> Build Options... -> Project and clear all fields (and I mean ALL fields) except for Include Path (C:\mcc18\h) and Library Path (C:\mcc18\lib).
You can also hit "Suite Defaults" to clear them for you, but make sure you have the Include Path C:\mcc18\h (no blanks).
Don't add anything else.
Unread 30-01-2005, 23:33
ElGeeko's Avatar
AKA: Kyle
#1375 (Megabites)
I did fix the error you talked about (I just copied and pasted from the other post). I do know about there being no blank c drive
Everything (but lib and inc, which are set correctly) is already blank. Still nothing.
If you want something done right, you gotta first read the <fine> manual and then do it the command line way.
Unread 31-01-2005, 09:26
Odd. The blankC is still there in your compile listing ( /i"C:\Dev-Cpp\include" /i" c:\code\code_v2.4), and the include setting for c:mcc18/h is not. I hope you didn't copy and paste from my post. That just highlighted the "blank" error.
Can you compile the default 2.4 code?
You show several paths that are not part of the MPLAB default settings, so I assume you set them up. Are you using the "Use Alternate Settings" in MPLAB look under Project -> Build Options... -> Project, then the MPLAB C18 tab? If you are then add the c:mcc18/h path there as well.
Your compile line should look like:
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8520 "main.c" -fo="main.o" /i"c:\mcc18\h" -D_FRC_BOARD -D_USE_CMU_CAMERA
If you cannot get the mcc18/h path into the compile statement you might consider uninstalling MPLAB IDE and reinstalling it.
Last edited by Mark McLeod : 31-01-2005 at 09:53. Reason: Whenever I edit the system adds lots of blank lines
Unread 03-02-2005, 23:57
Plloyd Plloyd is offline
Plloyd is an unknown quantity at this point
I am also having a problem with printf_lib.h
I can compile the default code, however, if i add the printf_lib.h and .c files that are in the default code directory, and attempt to use the printf function, it gives me the following error:
[path]\printf_lib.h:15:Error [1109] type mismatch in redeclaration of 'printf'
I am using v2.4 of the compiler (new computer - old version was never installed), and my build paths are all correct.
The error occurs whenever i include the printf_lib.h file
(ie, i can delete #include "printf_lib.h" and it will compile perfectly... put it back and i get the same error again).
Any help would be greatly appreciated.
Thanks,
Plloyd
Unread 04-02-2005, 07:38
Don't include the printf_lib.h or printf_lib.c files. They are old and no longer necessary.
The new compiler comes with a new printf routine. Adding the old printf routine on top of the default one caused the compiler to get confused about which of the two it should use.
Instead, add:
#include <stdio.h>
to any file that needs to use printf.
Unread 04-02-2005, 18:21
Thanks Mark,
that worked beautifully.
2005 default code kevin.fort Programming 33 20-01-2005 16:32
2005 RC Master Code or yaniv Programming 8 12-01-2005 12:05
2005 Manuals, FRC Default Code, Other resources Venkatesh General Forum 4 08-01-2005 14:06
Is default code already loaded? quickie25 Electrical 8 19-02-2004 22:51
