Go to Post Short answer, the GDC has ruled it legal explicitly through Q&A, implicitly through Q&A, and implicitly through the Manual. - EricH [more]
Unread 04-02-2005, 18:48
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: 32k controller limit
Originally Posted by Alan Anderson
The file size is not the same thing as the code size. The .hex file contains more than just the raw bits which end up in the flash memory of the controller. Look in the .map file to find out how much space the program is actually taking.
Indeed. It's in Intel-Hex (google for it if you really want to know). Mine is 69 KB, but the MAP file says that the code is using 72% of my program memory (or 24K).
Speed controllers won't communicate w/robot controller steven114 Control System 12 03-02-2005 21:26
Robot Controller File Size Limit ?? RoboGeek Programming 1 17-01-2005 19:59
2003 robot controller & interface LGuY Control System 3 04-04-2004 16:01
Help On Coding 2K1 Controller GregTheGreat Programming 9 05-12-2003 18:35
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
