Go to Post Dean will make America gracious again - seth.brugler [more]
Unread 04-02-2005, 20:46
occra 23.
AKA: ryo
None #1481
Re: pic: 1257's new tires
oh by the way if you're gonna put down power on these wheels youd prolly want sum hard foams inside. these rubbers may be grippy but that means flexible and tearable. with a couple lego motors and much gearing and much weight and much rough concrete ground was easily enough to rip up these. trust me. they arent designed for much force. unless you're planning on using them as freewheeling omnis. ex) as a replacement for casters. then you prolly wanna have lotsa support under these. oh and lego plastic wheels would not work lol. lego tends to be very brittle when it could be a bit stronger. well if you want durablitiy i suppose knex is flexible enough to stand a bit more
pic: 45 teaser pic 2 Kyle Love Robot Showcase 7 02-02-2005 23:22
pic: Team PIC of 354 Westinghouse HS CD47-Bot Robot Showcase 4 29-02-2004 12:15
pic: Team 1053's very first ever teaser pic CD47-Bot Robot Showcase 3 16-02-2004 22:56
TCP/IP on a PIC Venkatesh Electrical 1 18-11-2003 21:00
pic: Another pic of Team 930 CD47-Bot Robot Showcase 7 25-02-2003 21:07
