Go to Post Oh, and a general guiding principle: Don't be stupid. - Billfred [more]
Unread 04-02-2005, 22:35
MaxM's Avatar
MaxM MaxM is offline
#0473 (Corvallis High School Robotics)
Team Role: Student
MaxM is on a distinguished road
Send a message via AIM to MaxM Send a message via MSN to MaxM
Unhappy Kevin Watson's encoder code with RPM output
I'm the programmer on Team 473. I've been trying to use Kevin Watson's encoder code to measure the RPMs of our transmission in order to write a shift scheduler. I've been trying to do this by getting the number of encoder counts which occur over 25 cycles of Process_Data_From_Master_uP. Since Process_Data_From_Master_uP runs every 26.2 ms, I can convert from rpms into encoder cycles per Process_Data_From_Master_uP runs. However, this is not giving me anything near an accurate RPM output (I have a digital tachometer to check the RPMs with).
Here's my code from Process_Data_From_Master_uP:
	if (++counter >= (24))
		Left_Encoder_Count = Get_Left_Encoder_Count();
		printf("RPM Left: %5d\n",(int)((Left_Encoder_Count - previous_count_left)*0.698666667));
		previous_count_left = Left_Encoder_Count;
		counter = 0;
0.698666667 is the conversion factor counts per 25 Process_Data_From_Master_uP cycle to RPMs. (1 rotation/1 min*1 min/60 sec*1 sec/1000ms*655 ms (25*26.2ms)/1 program cycle*65 counts/1 rotation)
Either my conversion factor is totally wrong or my method is totally wrong (or my tachometer is wrong, but since it's digital I don't think it is). Can anyone help?
Thanks,
Max Masnick
Montana Robotics Team 473
Unread 04-02-2005, 23:40
Electrical Engineer
Rookie Year: 1995
Re: Kevin Watson's encoder code with RPM output
Two things...
1. The cycle time of 26.2 ms is approximate. To get accurate timing, write a timer interrupt routine.
2. Integer arithemetic! You are multiplying by 1... Try doing the math outside of the printf. Multiply by 6987 and store into a long int variable. Now divide by 10000 and store in an int variable. Now printf your int.
Regards,
Mike Betts
As easy as 355/113...
Unread 05-02-2005, 00:06
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Originally Posted by Mike Betts
...Integer arithemetic! You are multiplying by 1... Try doing the math outside of the printf. Multiply by 6987 and store into a long int variable. Now divide by 10000 and store in an int variable. Now printf your int.
Or multiply by 45788 (2^16 * 0.6986666...) and then right shift sixteen bits or just grab the high order sixteen bits of the thirty-two bit long. Man, I dig this stuff <grin>.
-Kevin
Kevin Watson
http://kevin.org
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
Kevin Watson's Kick-off Demo Code! Mr. Lim Programming 27 22-01-2005 03:38
Updated Encoder Code Available Kevin Watson Programming 2 04-01-2005 01:00
Rookie Programmer has question about the default code DanL Programming 3 26-01-2002 19:59
