pic: 1351 camera mount
Re: pic: 1351 camera mount
Sweet! That looks so much nicer than what we have right now. Is that plastic? Did you make it yourself? How much does it weigh? Sorry about all the questions but I really like that set up.
Looks great. Where are you planning on mounting it on your robot? And also how are you going to mount it, vertically or horizontally?
It's all aluminum. We had the opportunity to have some anodizing done for free, hence the black color. As for the weight, I'd have to weigh it, but I'd be surprised if the entire thing weighs more than half a pound. Actually...the servos are fairly heavy...so is the camera...so maybe it weighs a little over half a pound.
The chassis isn't finished yet, so we aren't sure how it will be mounted. However, the intent was to mount it just as it is in the picture. See this thread for CAD files/assembly instructions: 1351's camera mount |
The one problem that might get you mad down the road so I will save you the trip. The standard cable for the camera mount which is standard serial port is heavy and doesn't like to move around alot but if you got a handy person on your team have them make their own version of the same cable using the plug put cut the cord and instal more versital setup so the lil weakling servos they give us can move. Check the torque and I believe for Hitec servos like taht it should be around 85Oz/in. not much torque so whatch out.
The serial port is only used if you want to plug the camera into the computer. It is a pain, but not a permanent set up.
#7
| Scripting Setup and the Camera + Serial Port Drivers | CJO | Programming | 22 | 11-01-2006 17:42 |
| pic: Linear bearing + mount | Alex1072 | Robot Showcase | 6 | 02-02-2005 11:13 |
| Having trouble with your camera mount? | Chriszuma | Programming | 7 | 01-02-2005 22:12 |
| Camera Mount? | AnkurG | Electrical | 3 | 14-01-2005 09:26 |
| pic: 870 Motor Mount | CD47-Bot | Robot Showcase | 9 | 27-04-2004 11:55 |
