Go to Post GDC.... Come on. Counter-clockwise? ... I believe NASCAR might file a lawsuit! - Pavan Dave [more]
Unread 05-02-2005, 01:15
sciguy125 sciguy125 is offline
Electrical Engineer
AKA: Phil Baltar
FRC #1351
sciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond repute
Send a message via AIM to sciguy125 Send a message via MSN to sciguy125 Send a message via Yahoo to sciguy125
pic: 1351 camera mount
-----BEGIN GEEK CODE BLOCK-----
Version: 3.12
GE/S/P a-- e y-- r-- s:++ d+ h! X+++
t++ C+ P+ L++ E W++ w M-- V? PS+ PE+
5- R-- tv+ b+ DI+++ D- G
------END GEEK CODE BLOCK------
Unread 05-02-2005, 01:17
russell's Avatar
russell russell is offline
#1430 (WRONG)
Team Role: Electrical
russell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to all
Re: pic: 1351 camera mount
Sweet! That looks so much nicer than what we have right now. Is that plastic? Did you make it yourself? How much does it weigh? Sorry about all the questions but I really like that set up.
Unread 05-02-2005, 01:23
Jeff K.'s Avatar
Jeff K. Jeff K. is offline
Hmm..now what?
FRC #1138 (Eagle Engineering)
Jeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond repute
Send a message via AIM to Jeff K. Send a message via MSN to Jeff K.
Looks great. Where are you planning on mounting it on your robot? And also how are you going to mount it, vertically or horizontally?
Unread 05-02-2005, 02:17
Electrical Engineer
AKA: Phil Baltar
FRC #1351
It's all aluminum. We had the opportunity to have some anodizing done for free, hence the black color. As for the weight, I'd have to weigh it, but I'd be surprised if the entire thing weighs more than half a pound. Actually...the servos are fairly heavy...so is the camera...so maybe it weighs a little over half a pound.
The chassis isn't finished yet, so we aren't sure how it will be mounted. However, the intent was to mount it just as it is in the picture.
See this thread for CAD files/assembly instructions:
1351's camera mount
Version: 3.12
Unread 05-02-2005, 03:23
roboguy #1 roboguy #1 is offline
Unlicensed "Can Do It All"!!!
AKA: David
#1047
roboguy #1 is infamous around these partsroboguy #1 is infamous around these partsroboguy #1 is infamous around these parts
Send a message via AIM to roboguy #1
The one problem that might get you mad down the road so I will save you the trip. The standard cable for the camera mount which is standard serial port is heavy and doesn't like to move around alot but if you got a handy person on your team have them make their own version of the same cable using the plug put cut the cord and instal more versital setup so the lil weakling servos they give us can move. Check the torque and I believe for Hitec servos like taht it should be around 85Oz/in. not much torque so whatch out.
Unread 05-02-2005, 03:27
russell's Avatar
#1430 (WRONG)
The serial port is only used if you want to plug the camera into the computer. It is a pain, but not a permanent set up.
Unread 05-02-2005, 09:11
Electrical Engineer
AKA: Phil Baltar
FRC #1351
We actually didn't have much trouble with it. After clamping the assembly to a table, it didn't seem to care much about the heavy cable.
Version: 3.12
Scripting Setup and the Camera + Serial Port Drivers CJO Programming 22 11-01-2006 17:42
pic: Linear bearing + mount Alex1072 Robot Showcase 6 02-02-2005 11:13
Having trouble with your camera mount? Chriszuma Programming 7 01-02-2005 22:12
Camera Mount? AnkurG Electrical 3 14-01-2005 09:26
pic: 870 Motor Mount CD47-Bot Robot Showcase 9 27-04-2004 11:55
