5-volt custom electronics
We have some electronic assemblies that run on 5-volts, and we're trying to figure out the best way to power them while on the robot. Any suggestions? We were going to use a voltage regulating IC connected to the power supply through the breaker board. Is it safe to draw power from the digital outputs? How about 300ma?
Re: 5-volt custom electronics
http://ifirobotics.com/forum/viewtopic.php?t=71
We are powering our sensors that plug into the digital and analog inputs from those ports, so the voltage reference is the same. Our other circuits are going to be powered off the battery (through the circuit breaker panel, of course). Last edited by Joe Ross : 05-02-2005 at 11:30. Reason: more info about our plans |
Hmmm... Interesting. I know the CMUcam runs off power from the PWM ports, would that be a better option?
Heh. Some specifics on what youre doing with the electronics (and what you're using component wise) would be helpful. |
-Kevin |
#8
LM7805 in TO220 package (Radio Shack) from a fuse protected 12V source, you've got plenty of heat sink available I'm sure (120 pounds of it), but you shouldn't need much. Careful, the heat sink tab is connected to ground which means you better isolate it from the robot (FIRST rules I believe tell you this is a must). Don't forget an output capacitor, the LM7805 is funny that way sometimes, but other than that, it's solid as a rock. I love talking about my favorite chip, hope you get to use it!
http://www.ugrad.physics.mcgill.ca/Specs/LM7805.pdf |
| Drive Assembly Sprockets are Custom Bored | Mark Pettit | Kit & Additional Hardware | 35 | 09-03-2005 19:05 |
| Custom Colors and Weights in Inventor ? | sanddrag | Inventor | 3 | 26-02-2005 18:14 |
| Professional electronics board assembly [annotated collector's edition] | Geoff | General Forum | 7 | 17-02-2004 21:57 |
| custom electronics | Rickertsen2 | Electrical | 1 | 13-01-2003 00:15 |
| So what's in YOUR Custom Circuit this year? | kmcclary | Technical Discussion | 7 | 10-04-2002 12:20 |
