Go to Post My first reaction was "Where am I am gonna find pool noodles AND inner tubes in the middle of winter in Michigan?" - KTorak [more]
Unread 05-02-2005, 11:17
phrontist's Avatar
phrontist phrontist is offline
Proto-Engineer
AKA: Bjorn Westergard
FRC #1418 (Vae Victus)
phrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond repute
Send a message via AIM to phrontist
5-volt custom electronics
We have some electronic assemblies that run on 5-volts, and we're trying to figure out the best way to power them while on the robot. Any suggestions? We were going to use a voltage regulating IC connected to the power supply through the breaker board. Is it safe to draw power from the digital outputs? How about 300ma?
University of Kentucky - Radio Free Lexington
"I would rather have a really big success or a really spectacular crash and failure then live out the warm eventual death of mediocrity" - Dean Kamen
Unread 05-02-2005, 11:26
Re: 5-volt custom electronics
http://ifirobotics.com/forum/viewtopic.php?t=71
We are powering our sensors that plug into the digital and analog inputs from those ports, so the voltage reference is the same. Our other circuits are going to be powered off the battery (through the circuit breaker panel, of course).
Unread 05-02-2005, 11:29
phrontist's Avatar
Proto-Engineer
Hmmm... Interesting. I know the CMUcam runs off power from the PWM ports, would that be a better option?
Unread 05-02-2005, 11:53
Mike Hendricks Mike Hendricks is offline
misses his IFI control system
FRC #0973 (GRR)
Mike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to all
http://ifirobotics.com/forum/viewtopic.php?t=65
Heh. Some specifics on what youre doing with the electronics (and what you're using component wise) would be helpful.
2004-2010: Founding Member, Technical Mentor - Team 1388, Eagle Robotics
2011: ???
Unread 05-02-2005, 12:20
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
If you do use a voltage regulator be careful about the heat it generates. If you're dropping from the 12V battery voltage down to 5 volts, then you're dropping 7 volts across the regulator. Even drawing 100 milliamps from the regulator will cause it to get very hot. You'll want a heatsink to dissipate the heat or the regulator could go into thermal shutdown.
Unread 05-02-2005, 12:51
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
If you want 7.2V, yes, but then you'd still need a regulator to get it down to 5V.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 05-02-2005, 13:17
Kevin Watson's Avatar
La Caņada High School
FRC #2429
You shouldn't have any problem getting 300mA from the robot controller. If you use the venerable 7805, which is a linear regulator, you'll need to use a heat sink because it'll be dissipating at least 2.1 watts ((12-5)V * 0.3A).
-Kevin
Kevin Watson
http://kevin.org
Unread 05-02-2005, 16:43
briholton's Avatar
briholton briholton is offline
AKA: brian holton
#0752 (Gods of Fury)
briholton is on a distinguished road
LM7805 in TO220 package (Radio Shack) from a fuse protected 12V source, you've got plenty of heat sink available I'm sure (120 pounds of it), but you shouldn't need much. Careful, the heat sink tab is connected to ground which means you better isolate it from the robot (FIRST rules I believe tell you this is a must). Don't forget an output capacitor, the LM7805 is funny that way sometimes, but other than that, it's solid as a rock. I love talking about my favorite chip, hope you get to use it!
http://www.ugrad.physics.mcgill.ca/Specs/LM7805.pdf
"Youth is wasted on the young"...MT
Drive Assembly Sprockets are Custom Bored Mark Pettit Kit & Additional Hardware 35 09-03-2005 19:05
Custom Colors and Weights in Inventor ? sanddrag Inventor 3 26-02-2005 18:14
Professional electronics board assembly [annotated collector's edition] Geoff General Forum 7 17-02-2004 21:57
custom electronics Rickertsen2 Electrical 1 13-01-2003 00:15
So what's in YOUR Custom Circuit this year? kmcclary Technical Discussion 7 10-04-2002 12:20
