Go to Post I GET that FIRST is about more than winning on the field. BUT... ...it is my experience that the great programs of the FIRST world almost always build on a foundation of competitive robots. Success on the field begets success in other realms. - Joe Johnson [more]
Unread 05-02-2005, 12:20
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Re: 5-volt custom electronics
Originally Posted by phrontist
We were going to use a voltage regulating IC connected to the power supply through the breaker board.
If you do use a voltage regulator be careful about the heat it generates. If you're dropping from the 12V battery voltage down to 5 volts, then you're dropping 7 volts across the regulator. Even drawing 100 milliamps from the regulator will cause it to get very hot. You'll want a heatsink to dissipate the heat or the regulator could go into thermal shutdown.
Drive Assembly Sprockets are Custom Bored Mark Pettit Kit & Additional Hardware 35 09-03-2005 19:05
Custom Colors and Weights in Inventor ? sanddrag Inventor 3 26-02-2005 18:14
Professional electronics board assembly [annotated collector's edition] Geoff General Forum 7 17-02-2004 21:57
custom electronics Rickertsen2 Electrical 1 13-01-2003 00:15
So what's in YOUR Custom Circuit this year? kmcclary Technical Discussion 7 10-04-2002 12:20
