Go to Post Canada has five regional events now. Canada. - Nick Lawrence [more]
Unread 05-02-2005, 08:52
Mirza95vx Mirza95vx is offline
The BOSNIAN
AKA: Mirza Strujo
None #1511 (Rolling Thunder)
Mirza95vx is a jewel in the roughMirza95vx is a jewel in the roughMirza95vx is a jewel in the roughMirza95vx is a jewel in the rough
Send a message via AIM to Mirza95vx
Weight Reduction Help.
Were a rookie team this year team 1511 and i am wondering how many teams are reducing the weight of their drivetrain/ gearbox. Any help would be awsome.
Unread 05-02-2005, 09:24
Re: Weight Reduction Help.
Couple of examples shown here:
http://www.chiefdelphi.com/forums/sh...ad.php?t=33481
Unread 05-02-2005, 10:33
The BOSNIAN
AKA: Mirza Strujo
We already took a lot of weight out of our gears. Any other ideas?
Unread 05-02-2005, 12:46
jrocket567 jrocket567 is offline
FRC #0617
jrocket567 will become famous soon enoughjrocket567 will become famous soon enough
sawsall and giant holesaws
take the main channels/tubes of the robot and put a bunch of holes in them with a holesaw.. the result--> swiss cheese... just make sure you dont completely compromise the integrity of the robot..
Unread 05-02-2005, 23:57
DarkJedi613's Avatar
DarkJedi613 DarkJedi613 is offline
Running Riot
AKA: Patrick Cloke
FRC #0358 (Hauppauge Robotic Eagles) FRC #1493 (RPI/Albany High School)
DarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to behold
Send a message via AIM to DarkJedi613 Send a message via MSN to DarkJedi613 Send a message via Yahoo to DarkJedi613
It would help to know what your robot looks like before offering ideas about it. Perhaps show a picture?
You can try lightening metal, welding instead of bolts, using thinner skins (or no skins), or drilling out holes.
2003 - 2006 President, Coach, Webmaster Team358.org
2008 Mentor, Team 1493
Team Search | (Updated: 1-16-08)
FIRSTsearch
Unread 06-02-2005, 11:13
Mike Martus's Avatar Unsung FIRST Hero
Mike Martus Mike Martus is offline
FRC #0051 (Wings of Fire)
Mike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond repute
One of my jobs with FIRST in the past few Years has been inspector at many events. I have seen many machines that look like moths have attacked it, with holes everywhere. You know a team is in trouble when you see several students attacking their machine with hole saws on Thursday. The holes are not to create less wind resistance.
What really needs to be done is "Weight Management". Drilling holes is only a partial answer and only if you are drilling steel. There is very little weight savings with lighter materials.
Look at each sub-system in detail. What supports and brackets are vital and necessary for strength and durability, which can be eliminated? Do you really need a gear made of steel, when a lighter material would work as it is not going to see massive stress?
Do you have extra wire? Cooper is very heavy. Are you using the correct wire gage?
Finally, call a meeting of the leaders of each sub system and give them a target weight they can have or a amount they must loose. Making the final weight is important.
Mike Martus
Unread 06-02-2005, 13:51
Michael R. Lee's Avatar
Michael R. Lee Michael R. Lee is offline
BLT= Brave Little Toaster
Michael R. Lee will become famous soon enoughMichael R. Lee will become famous soon enough
Send a message via AIM to Michael R. Lee Send a message via Yahoo to Michael R. Lee
Also consider pulling functionality off your robot. Generally (discounting the drive train) consider doing only 1 or 2 things within the game... usually n tasks, n - 2 for time and then from that subtract 1 for weight. For example, this year you could be grabbing a tetra off the stand and putting it on a goal. If you've been following the good advice of the people here and lighting up your gearbox.... you got to take the weight off elsewhere. The "stock" FIRST transmission they gave use needs serious machine time to make it "reasonable" to install.
“Ad Astra Per Aspera”
(A Rough Road Leads to the Stars)
Northeastern University College of Engineering
Class of 2008, Mechanical Engineering
Go HUSKIES!
Unread 06-02-2005, 17:53
occra 23.
AKA: ryo
None #1481
nahh minis are quite light relative to the 80% SUV population around here.
if you are using solid rubber tires, thats also another place you could choose to drill into. but dont make the holes too big or too close or you will have a 'flat' solid (with holes in it) rubber tire
and if your axles are longer than they need to be cut them off. but remember to leave enough for the collars if that is how you secure them. those 1/2 in axles are quite heavy. and drilling your gears/sprockets will definitly help
Unread 06-02-2005, 18:12
MasonMM's Avatar
MasonMM MasonMM is offline
AKA: Mason Markee
FRC #0118 (Robonauts)
MasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond repute
also think about rebuilding certain parts with a lighter material.. consider 1/16 inch wall aluminum box or angle instead of 1/8 inch. If you have alot of PVC, consider small walls, or switching to some aluminum of smaller size that can get you the same strength but less weight.
Unread 06-02-2005, 18:20
Yan Wang's Avatar
Yan Wang Yan Wang is offline
Ithaca is Gorges
AKA: John Wayne
FRC #0639 (Code Red Robotics)
Yan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud of
Send a message via ICQ to Yan Wang Send a message via AIM to Yan Wang Send a message via MSN to Yan Wang Send a message via Yahoo to Yan Wang
Many teams use [1/4"] steel bolts to connect parts when a [quarter-inch] aluminum dowel with pins on the end can do the same job. Last year, our robot, when hanging, was supported by a 2" long dowel. The little bits of weight you save do add up.
Code Red Robotics Team 639 Alumnus | www.team639.org
<Patrician|Away> what does your robot do, sam
<bovril> it collects data about the surrounding environment, then discards it and drives into walls
Unread 07-02-2005, 00:30
Zippiot Zippiot is offline
punching bag
Zippiot can only hope to improve
Send a message via AIM to Zippiot
if you only need to get rid of a few lbs cheese holing everything can help, turn your gears into patterns like car rims, but remember to keep at least 3 supports for each section that you take chunks out of.
Unread 07-02-2005, 16:03
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Length of chain and chain pitch used in drive mechanisms can also reduce weight. If you can shorten the chains by relocating the drive/transmission closer to the mechanism it will add up fast. Also if you use No. 35 chain every where look at the actual loading that you see at different locations. My team was shocked last year when I showed them that No. 25 chain could take the load for a 2 motor drivetrain. We had typically used No. 35 and it hadn't been questioned. I just want to stress though make sure you do the stress calculations before making this change.
Pete
Robot Weight Limit: Rule Conflict Specialagentjim Rules/Strategy 10 06-08-2005 17:52
Under or over weight? Kyle General Forum 109 22-02-2005 10:09
Breaker Panel weight Emily Pease Electrical 4 24-01-2005 12:22
Robot Part Weight List Don Wright Technical Discussion 3 20-01-2005 12:55
Lots of Wheels and F = u x N archiver 2001 17 23-06-2002 23:37
