Go to Post If all you are is a nail, every hammer looks like a problem. - Alan Anderson [more]
Unread 05-02-2005, 13:37
Veselin Kolev's Avatar
Veselin Kolev Veselin Kolev is offline
X51 Production Company PGM (TM)
Veselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond repute
Re: Van Door Motor Problem
Ok...
People are starting to panic because it is week 5 now and such motor problems are not appreciated. Anyway. On to the point.
I have been looking around all over the place to find accurate van door specs. I have not found any. All of them are still the same old ones. Which are very wrong. The information in my first post is correct, it was actually measured. However, all we measured was theoretical power and free speed. So.. has anyone measured the actual stall torque, max efficiency, etc? I have lost my confidence in spec sheets.
Unread 05-02-2005, 14:39
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
I asked a question about this on the FIRST Q&A System and it was deleted... who knows what FIRST is doing.
http://www.mikesorrenti.com/
Unread 05-02-2005, 17:22
Bolotov's Avatar
Bolotov Bolotov is offline
Assuming a helical robot...
#0115 (MVRT)
Bolotov is an unknown quantity at this point
Send a message via ICQ to Bolotov
So does anyone have the stall torque numbers for the new vandoor? Without it, there is no equation, and without the equation there is no redesign...
- ...but ze hole point off zuch a divize iz lozt iff you keep eet a ZEKRET! WY DEED YOU KEEP EET A ZEKRET?!!!
- We were going to announce it on Monday's Party Congress. As you know, our Premier loves surprises.
- Bolotov, AKA Lucius Julius Catilina Felix
Unread 05-02-2005, 18:12
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Apparently.. :sigh: I have found something that opens an even more frustrating question to this problem.
http://www2.usfirst.org/2005comp/Specs/Taigene_PSD.pdf
shows the spec for motor number:
Specification for motor 16638628 & Specification number 166198
While the motor we received was actually (as shown in the picture below) number 16644829 Rev02.
This irritates me. Did we get the wrong motor? Are the spec sheets on the FIRST website the wrong one?
:sigh:
Can someone else post as to what number their motor says.
Oh, and BTW.. going by the spec sheet that is on the FIRST site, which says 52RPM at 10.5v and 76 @ 12 Volts, then I believe the spec sheet may be right, and we got the wrong motor. Just a thought though.
And, to add to this, I personally checked the voltage at the connection of the Van Door and it was around 12v.
edit: Overall pic of the thumbnail below is found here.
http://www.team237.com/gallery/Build...DR_2250_Medium
Unread 05-02-2005, 20:11
Swampdude's Avatar
Swampdude Swampdude is offline
AKA: Dan Quiggle
FRC #0179 (Children of the Swamp)
Swampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond repute
I did an RPM check on our kit van motor and it ran 78rpm
www.179swampthing.org
Unread 05-02-2005, 20:24
Did the sticker on the motor call out the same part number as the one I attached a thumbnail of, or the spec sheet motor? Cause they seem to be two different models, and/or part numbers.
Unread 05-02-2005, 20:26
Swampdude's Avatar
AKA: Dan Quiggle
Sorry I didn't check it, but I will tommorow and let you know
Unread 05-02-2005, 23:48
Gary Bonner Gary Bonner is offline
FRC #3974
Gary Bonner has a spectacular aura aboutGary Bonner has a spectacular aura about
I opened ours up. This year’s has a ~104 tooth worm gear (as best as I can count without complete disassembly) and a worm with two threads for a 52:1 reduction. A prior year’s (with a 75rpm free speed) had a 65 tooth worm gear and a single thread worm. So the speed reduction is not due to the gearing.
Unread 06-02-2005, 03:29
Ok. What was the part number on the sticker of yours?
Unread 06-02-2005, 16:39
Biff Biff is offline
AKA: Tom Cooper
#1227 (Techno Gremlins)
Biff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the rough
Tested ours, this years 51 rpm battery voltage 12.4, Last years 78 same battery voltage. Both will back drive with a wrench, BTW no speed difference on this years motor forward or backward. Sticker on the motor is similar to one further up in the post. Didn't check the numbers yet. Will do and and edit this post. Ours is the rev 02 and part number 16644829 the same as the pic posted by Elgin Clock post #19
Tom Cooper 1227
Unread 06-02-2005, 20:04
Bolotov's Avatar
#0115 (MVRT)
Wow, our motor number (16640238 rev 4) is different from both the spec sheet and the thumbnail above. Today, we did a whole lot of testing with textbooks and a multimeter on it, and we'll come up with a power curve for this given model, and post it up if anyone cares/is willing to believe our Überghetto experiments. What's really annoying is that there are 4 different models of the "same" motor mentioned in this thread only... What does FIRST have to say on this variety?
Unread 06-02-2005, 20:40
roboticsguy1988's Avatar
roboticsguy1988 roboticsguy1988 is offline
Larry Johnston
AKA: Larry Boy
FRC #1501 (Team THRUST)
Team Role: Electrical
roboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud of
Send a message via ICQ to roboticsguy1988 Send a message via AIM to roboticsguy1988 Send a message via MSN to roboticsguy1988 Send a message via Yahoo to roboticsguy1988
Yeah............ ours was going slower than previous years motors have. i am not sure about the RPM's though.
Larry Johnston, Team THRUST, Team #1501, Team THRUST webpage
2005 IRI - Imagery and Design Award
2005 - 2006 BMR - Professional Grade Award
2006 BMR - Delphi Driving Tomorrow's Technology Award
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~ RogerR
~Da team that uses all tha rivets, Team #1501~
The FIRST Software Repository ~ Chief Admin
openFIRST ~ Project Supporter (Former editor)
DMOZ.org - FIRST - US Teams Section ~ Chief Editor
Unread 06-02-2005, 20:43
Projectchon's Avatar
Projectchon Projectchon is offline
AKA: William Lei
FRC #1009 (Vainer Robotic)
Projectchon can only hope to improve
My reply is a bit off, but...
HOW do you attch the shrift of the Van door to a gear or spock
Team 1009
Unread 06-02-2005, 20:54
Josh Siegel's Avatar
Josh Siegel Josh Siegel is offline
lurker
#0448 (Crandroids)
Josh Siegel will become famous soon enough
Send a message via AIM to Josh Siegel Send a message via MSN to Josh Siegel
We filed/drilled a tiny 'dent' into the shaft and tightened a setscrew into it. There are othe ways, too.
I didn't time our motor, but our arm was geared based on the specsheet and performing exactly as expected (time/torque wise).
Unread 06-02-2005, 21:01
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
We got a full 80 rpm from ours on a charged battery.
Van Door Motor Thermal Overload Protection bigqueue Motors 1 23-02-2004 07:16
Van Door Motor Drawings Jonathanb Motors 9 03-02-2004 18:32
Attn Wildstang: Found your van Wetzel Chit-Chat 4 21-04-2003 21:41
We can't compete, need van door motor archiver 2000 1 23-06-2002 22:59
van door question archiver 2000 1 23-06-2002 22:27
