Greeting,
I am about to throw this camera out the window i'm so confuzeled. What my problem is, is that i cant get the java camera thingy to work it says: Looking for camera... I had it working once and now it wont, Now when i start up the java app the red led turns off and it stops working. Has anyone else had this problem or has any insight on how i might fix it. Thanks |
Re: CMU Problems
Re: CMU Problems
Unfoutunatly It doesn't work and we have the latest version and the TLL is not plugged in But thanks for the help anyways
Re: CMU Problems
Try recharging the 7.2v backup battery. We had that problem before, and then we charged the backup battery, and the next day it worked again.
Dan Team 375 |
Re: CMU Problems
Just to add my $0.02.
We have observed the following -The camera powers from the backup battery , it must be charged. - If TTL port is connected to the R/C the camera will not work witht he Java applet (for us) -If you have your IFI loader running you wont be able to run your Java applet since your COM port is already being used. -Sometimes you need to turn the camera off and then on to make it work |
Re: CMU Problems
-make sure your PWM's are gving out more than 5 VDC (we had that problem, then we just ran the camera off of a seperate 12V battery with limited current)
- the jumper near the top right of the camera across form the serial cable needs to be on -be sure you get a red and green LED lights -if you haven't already configure the serial port to the proper data bit rate. -Just power the PWM at the bottom and use the serial to your computer. that's all i can think of now |
#7
Re: CMU Problems
I don't want to renew this thread, but I don't understand how I can get red and green LED lights on together. I tried unplugging everything and leave it alone for a few minutes (that worked once or twice), turning it on and off, toying with the whole thing, but nothing works. I know this question has been asked many, many times on this forum, but can someone make a general enlightenment to my aching head?
| The *BIG* CMU Howto | pi_guy578 | Programming | 17 | 21-12-2005 13:24 |
| PC problems. . . | opnickc | IT / Communications | 5 | 12-01-2005 16:53 |
| Robot Rodeo - fixing control problems | Gary Dillard | Off-Season Events | 7 | 26-10-2004 00:46 |
| Joystick problems | archiver | 2001 | 3 | 24-06-2002 02:40 |
